Home > Technical > Snow Cowl - Are they necessary
Butchers Boy
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
I don't have one of the 'Snow Cowls' on my 2010 Defender 90 should I get one? We don't get mush snow here in the South or do they have another purpose that's useful?
I actually prefer the looks of the 'Hi-Force Wing Top Air Intake' would they do the same job? Question 2010 Defender 90 HT
The longer I live..... The better I was!
Post #492798 15th Jan 2016 11:24pm
JAY BOY
Wales
I'm not keen on them either. They do a job but if you're not going off roading and parked under a tree in autumn i can't see the need. Lots of folks like the look. Thumbs Up
I've had a few Defenders and never had a snow cowl and never had any problems.
Post #492810 15th Jan 2016 11:41pm
leeds
Do not think snow cowl. Think heater air intake cover!
One of the quirks of LR Defenders is why LR put the air intake on a flat horizontal surface whereas the engine air intake is on a vertical surface.
Brendan
Post #492815 15th Jan 2016 11:52pm
Anderzander
Quite a bit on this current thread : http://www.defender2.net/forum/topic43076.html
Post #492818 16th Jan 2016 12:04am
Butchers Boy
Have ordered one thanks guys Thumbs Up
i will remove the heater mesh on top wing and check to see how much rubbish is stuck down there before I fit it 2010 Defender 90 HT
Post #492824 16th Jan 2016 12:26am
Cupboard
Picking up on Brendan's point, how hard would it be to fit an air intake on the side (where the older Defenders and Land Rovers had them) matching the current air intake, and plumb the heater up to that instead?
Post #492868 16th Jan 2016 10:26am
Litch
The Hi-Force vent and snow-cowl do entirely different things.
Having had both I can confirm the the Hi-Force vent is very effective in ensuring there is a decent air-flow through the heater (even with the motor turned off) whereas the snow-cowl (in my experience) actually reduces the air-flow but of course does prevent the grill getting blocked when it snows.
I unfortunately sold my H-Force vents (bad decision) when I bought a snow-cowl and now just fit the cowl when snow is likely and/or forecast (which isn't often around here). ONE LIFE, GET IT!
Post #493114 16th Jan 2016 11:19pm
Ranger
United Kingdom 2003 Defender 110 Td5 G4 LE Zambezi Silver
+1 for the Hi Force. The snow cowl was I believe only introduced for the military winterised versions, but civvie's soon picked up on it as being cool! Its only to prevent a build up of snow, not leaves or any other sh*te. Remove the rubber bung at its base and you'll not get any build up of crud. Use the Hi Force for a better look and adequate cool air intake.
Post #493145 17th Jan 2016 1:04am
jimbob7
TBH,dunt reduce condensation much on mine,but does break up the bodywork 100%..So will keep it! Pov.spec,ftw. 2006, 110,TD5.
Post #493722 18th Jan 2016 4:58pm
Grenadier
Butcher's boy. As someone who lives in a world where it occasionally snows, my HF Vents work perfectly well. The farm has a nice overhang on the roof, but not enough to cover both sides of the Def. The way I park means the RHS is always exposed and when it dumps, gets covered. Occasionally I have to leave the whole Def out. In either instance, No issues whatsoever. I think the HF vent looks cooler, so if you really must cover, but of cardboard will suffice. Whip it off (the cardboard that is) before you drive and head off looking far, far, far cooler than those with the snow cowl. Um. Haven't you just bought one? Whistle
 Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #493767 18th Jan 2016 7:04pm
Butchers Boy
Thumbs Up Rolling with laughter Thanks Grenadier I'll do my best to whip it off before I pull away ! I have to agree the HF dose look a lot better IMHO
One (not even delivered yet) Snow Cowl For Sale Rolling with laughter !!!! 2010 Defender 90 HT
Post #493780 18th Jan 2016 7:14pm
Is anything necessary, that people bolt on to their Defenders?? Laughing
The best mod to do to your heater intake, is to remove the rubber bung, that sits at the bottom to let water out.
It gets clogged up and doesn't work anyway. This way, water will run out and you will notice a massive difference in the lack of steaming up your windows will do Thumbs Up
Post #493960 19th Jan 2016 9:21am
Butchers Boy
Thanks GREENI that is a good peice of advice I'll check that today My windows steam up very quickly 👍👍 2010 Defender 90 HT
Post #493973 19th Jan 2016 9:49am
Open your bonnet and rub your hand under the intake, just grab hold of the bung and pull. It's worth running some hot water in your intake to get rid of the build up of leaves/litter/spiders/grannies that have been sucked in.
Post #493977 19th Jan 2016 10:00am
