Home > Camping, Caravanning and Holidays > Nato socket to 7 pin converter? is there such a thing
Stacey007
Hello
Thinking in my head about converting the nato lights on a trailer I was going to un do the Nato plug and wire into a junction box and then attach a 7 pin plug to the other end so it could always be converted back?
this idea (taken from another build on this forum
However an easy plug and play fix would be something like below? but is there such a thing? from a Nato plug to a 7 pin plug? (I have not found one as they are all 13 pin to 7 )
Then all I would need to do is change the bulbs?
Thanks
Post #492620 15th Jan 2016 3:25pm
You'll nly need to change the bulbs if the trailer is 24Volt.
There is no COTS adaptor available to or from the NATO 12-pin set up, because the people who use NATO sockets don't use civilian equipment.
You could obtain the NATO socket from the back of a military vehicle and wire it onto one end of a lead with a seven pin 12N plug (or 13 pin, whatever you need) on the other, but it is going to be far less convenient that simpy fitting a normal lead to the trailer. Realistically, when are you going to want to use a NATO 12-pin connector on your trailer? Unless you own an ex-military LR, it is functionally useless!
My advice is to remove the complete 12-pin plug and lead, replace it with a 7-pin plug and lead, and keep the NATO lead you have removed in case one day you do want to restore the trailer to as-built condition.
Post #492656 15th Jan 2016 5:15pm
Stacey007
Good call to be honest and your right,
I'm unlikely ever to need the 24V Nato plug. So just store it.
Is it a straight forward job to wire in the 7 pin socket as I would like the front lights and rear fog to actually work,
Thanks
Post #492748 15th Jan 2016 8:52pm
dorsetsmith
Re: Nato socket to 7 pin converter? is there such a thing
Stacey007 wrote:
Hello
Thanks
http://www.towingandtrailers.com/technical...agram.html
Post #492759 15th Jan 2016 9:11pm
NATO PLUG
A & H: Spare
B: Left hand stop
C: Convoy
D & L: Earth
E: Tail and number plate
F: Fog lamps
J: Right hand stop light
K: Aux positive
M: Left indicator
N: Right indicator
Now convert to a 7 pin
Yellow 1 to M left hand indicator
Blue 2 to F fog lights
White 3 to D earth
Green 4 to N right hand indicator
Brown 5 to E tail and number plate light
Red 6 to B & J left hand stop & right hand stop
Black 7 to E tail and number plate light
Post #492800 15th Jan 2016 11:26pm
Stacey007
Many thanks doe the 7 pin not have a Fog light?
Thanks again very useful
Post #493030 16th Jan 2016 8:14pm
Yes, Pin 2 as noted in my post above.
The 12N pin allocations are as follows, with the colours used in 7-core trailer wire:
1 - Indicator Left (Yellow)
2 - Rear fog light (Blue)
3 - Earth (White)
4 - Indicator Right (Green)
5 - Offside side, marker & number plate light (Brown)
6 - Brake lights (Red
7 - Nearside side, marker & number plate light (Black)
Post #493573 18th Jan 2016 9:33am
Stacey007
My Bad,
Sorry I didn't read it correctly...
Post #493580 18th Jan 2016 9:58am
Mdm
heres one we made earlier
Post #776939 10th Jun 2019 7:51pm
