![]() | Home > Puma (Tdci) > Diff wind-up |
| Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060
The two seperate functions, are connected only by the lever. You can select them independant from one another, or in combination. It is wise to use both occasionally in order to remain familiar with their function and how to select them. And to be sure that when the moment does arise, they will do the job as intended. They are both important "weapons" in the Defenderīs armoury 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
| All times are GMT |
