Home > Td5 > No Brake Lights ! Help
Tank
Scotland 2004 Defender 90 Td5 HT Zermatt Silver
Help !
No brake lights !
Changed the lights to Wipac Led's a few weeks back and all has been good until now.
I have had problems with the dim dip relay and need to remove it. Can this have an effect on the brake lights ? It's like they aren't getting enough voltage and are very dim ! Not good on the winters nights !!!
Any ideas please ?
Tank
Post #492428 14th Jan 2016 11:15pm
mk1collector
Maybe mud or water in the tow socket shorting them? There's a plug under the drivers side wheel arch to disconnect to rule it out. Ray
My build thread
Post #492459 14th Jan 2016 11:55pm
Tank
Ah ha that could be it as the green tow light in on the dash ! The one that comes on when you are towing and signal Smile
Where is the plug ? What does it look like !
I was wading in deep deep water a few weeks ago !
Thanks again for advice Smile that's why this forum is so good Smile
Post #492461 15th Jan 2016 12:10am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Do you have access to a multimeter to check voltage? The brake switch is located in the pedal box and connected via two spade connectors, disconnecting this and bridging the two cables can test the entire circuit minus the switch. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #492463 15th Jan 2016 12:13am
Tank
I do, but rubbish at car electrics Smile I think the tow sort may be the problem as the green tow light is on on the dash . Just need to find out where this plug is mentioned by m1collecter earlier
Post #492466 15th Jan 2016 12:20am
Mash
In and around the right hand rear wheel arch, should be close to the rear light loom you can follow from where it exits the chassis. I haven't looked at the Td5 tow electrics though, have you tried a squirt of wd-40 in the actual tow socket? 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #492470 15th Jan 2016 12:27am
mk1collector
As mash says, follow the tow socket wiring under the rear arch to a grey plug just above the rear crossmember and unplug. If the lights still don't work the tow socket is ruled out so simply plug it back in Thumbs Up Ray
My build thread
Post #492514 15th Jan 2016 10:24am
Tank
Totally confused !
Took the tow bar electric plug apart and it was fine. No rust contacts all good. Still have the green light on the dash !
Rear lights work ok. Brake lights are really dim ??
The dim dip is knackered however when I do the wire bypass I have no lights, and I did the right bypass by the way.
Can the brake light switch at the pendal not be working right and therefore not getting the voltage to the rear brake lights ?
Aaaaaaaahhhhhh help
Anyone know a good autoeletricain in Dunfermline ?
Everything was working fine until my dim dip relay went ! Will guy another one in the mean time !
Post #492789 15th Jan 2016 10:51pm
Tank
Lights off, brake lights are bright
Lights on , brake lights dim !
The Wipac Led's worked great to start with, they can't be the problem can they ?
Post #492808 15th Jan 2016 11:37pm
mk1collector
Check all the earths Ray
My build thread
Post #492834 16th Jan 2016 1:32am
Tank
Jeez ! Which ones ?
Post #492835 16th Jan 2016 2:03am
Mash
I'm sure there is a chassis Earth at the rear of the vehicle this would be where I would start, it really is a case of looking until you find one. There are several on the chassis. Once you find an earth remove it,clean it up ensuring it will have a good conductivity and then make sure it's tight. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #492867 16th Jan 2016 10:25am
Tank
Continuing the silly questions !
The Wipac led lights have two wires. They are combined rear lights and brake lights there is no earth wire ? Is one of the wires earth or are they both power one for the rear lights and one for the brakes ? How do the led's Earth ? Through the screws ? Sorry know it's a stupid question but I am confused !
Thanks again for the advice
Post #492937 16th Jan 2016 2:33pm
