![]() | Home > In Car Electronics > Temporary CB aerial mount? |
dantastic Member Since: 04 May 2010 Location: London Posts: 367 ![]() ![]() |
I need to use a CB radio in my Defender for a 2 week trip. I won't need it permanently so I don't want to drill any holes!
I have looked at the gutter mounts but they seem to be damaging the softer, rubbery compound in the gutter channel. I was thinking, What if I attach the aerial to a suction mount? I know I need to use an artificial ground plane but apart from that, will the suction mount be string enough? I'm thinking one of these http://www.ram-mount.co.uk/heavy-duty-suct...8_446.html Or are there better methods of mounting CB aerials which doesn't involve any damage? |
Stick a magmount on your bumper?
stanley Member Since: 18 Sep 2009 Location: Dorset /hampshire Posts: 1033 ![]() ![]() ![]() |
If you have a roof rack or bars then a clamp like this will do
![]() Or fabricate a bracket to go behind the rear door hinge ![]() |
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 625 ![]() ![]() ![]() |
I used a gutter mount from 4x4CB:
http://www.4x4cb.com/public/item.cfm?itemID=1749 Works well, but where I have poked the cable underneath the seal for the second row doors it leaks a bit in heavy rain, but ok for temporary use. |
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 620 ![]() ![]() ![]() |
If you have Puma Defender you have a steel bonnet - ideal for mag mount ariel - that's where mine is going!!
Ranger Member Since: 17 Nov 2011 Location: United Kingdom Posts: 75 ![]() ![]() ![]() |
Or use a Midland handheld, plugs into your cigarette lighter socket and is good for 3-5 Km
http://www.thunderpole.co.uk/handheld-cbs/midland-42.html |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 926 ![]() ![]() ![]() |
I knocked up a bracket to mount on the back door top hinge. Used a offcut of stainless and bent and drilled to shape. I might get round to making more when I get 5 minutes and the weather improves
Do let us know if you find yourself with a surplus mount you want to sell
