Home > Technical > Clutch pedal assist kit
CarMan
Does anyone have any experience of using or fitting one these
http://www.paddockspares.com/clutch-pedal-...ender.html
the pedal is quite heavy in my 200 and I thought it might be worth a try and maybe not too difficult to fit? Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #491049 11th Jan 2016 4:57pm
Martin
Site Admin
I think on a 200 Tdi you will need a complete Td5/Puma pedal as the spring kit does not fit the earlier pedal.
I might be wrong though! Embarassed
I have changed the soft top's pedal assembly, it was originally a TD.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #491050 11th Jan 2016 5:04pm
miker
Put one in my td5, much nice than the stock long spring. Pedal movement feels a bit odd at is kind of has a deadband at the bottom of its travel, but overall a vast improvement
Post #491052 11th Jan 2016 5:05pm
RRUK
I did it on my TD5 and the main hard part was removing the moulded floor covering as it is so stiff.
As Martin says, you'll need to check if it's even something you can do on a 200Tdi. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #491064 11th Jan 2016 5:31pm
Martin
Site Admin
The clutch pedal assembly was not badly priced as a new part last year, it's tripled in price since then Sad
You'll probably pick up a second hand one OK.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #491066 11th Jan 2016 5:37pm
CarMan
hmmm I'm glad I asked. The Paddocks description says it will fit all 90's however I've found an ebay listing for the genuine part number which says will only fit late 200tdi onwards from VIN LA939892 and mine is LA931*** so I'm assuming it won't fit Big Cry
Thanks for the advice guys Rob
Post #491082 11th Jan 2016 6:14pm
