Home > Puma (Tdci) > Found this in my fusebox, anyone an idea where it came from
Vanderbult
Netherlands 2011 Defender 90 Puma 2.4 SW Santorini Black
The other day i was installing my Alpine subwoofer and i was checking some fuses under my steering wheel fuse box and this rubber knob said hi.
anyone an idea where it might have came from?
Best wishes to you all for 2016!
Post #491018 11th Jan 2016 3:54pm
Looks like it's from the steering column cowl?
Post #491019 11th Jan 2016 3:57pm
ericvv
One of those sits in a unused hole at the right side of your steering column, the location in the picture below where I installed the lighted button for the Scenelight. Now, what it did in your fusebox, can't tell you. Laughing
Eric
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #491021 11th Jan 2016 4:02pm
Vanderbult
hahah oke! i've been wondering what that hole was for.
So, what is that hole for? besides for the rubber knob i found in my fuse box
Post #491026 11th Jan 2016 4:04pm
That hole was for the choke cable on petrol-engined Series 3 vehicles (because the cowl is a Series 3 part)!
The bung blocks the unused hole.
Post #491029 11th Jan 2016 4:07pm
Retroanaconda
The Series III cowl is quite different, being the mounting place for the fusebox for one.
90/110/Defender were of course available with petrol engines, hence the hole for choke cable.
Post #491225 11th Jan 2016 10:26pm
Yes, of course, my mistake! Thank you. Thumbs Up
Post #491229 11th Jan 2016 10:34pm
