![]() | Home > In Car Electronics > Twin USB unit in 2007 Defender. |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1784 ![]() ![]() ![]() |
Honestly?
Cheap crappy chinese switch mode PSU with poor EMI performance, causing the noise. |
If you are not going to use it at the same time as the 12v socket, why not just plug a quality dual USB in?
Toplink Member Since: 05 Dec 2010 Location: Somerset Posts: 159 ![]() ![]() |
In fairness not a cheap unit. and plugging in a unit to the lighter socket looks naff. Its never over in my land rover.
2007 Defender HTop. 1952 Series One 80" 1977 Muir-Hill 111. 2014 Triumph Tiger800xc 1999 Discovery 2 td5 1982 Ransomes TSR300D. 2002 Yamaha XT600e. 2010 Freelander2 (the wifes) 2008 John Deere X140 |
Got a link? To be honest, even a lot of the not cheap stuff often has poor EMI performance. Could be worth getting a replacement? Might be a build issue.
Just a thought - do you have the + a - crossed over?
No sure this would cause the problem but the USB device might have still work but cause problems? |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3411 ![]() ![]() |
I bought a really low profile, dual plug in jobbie of ebay for Ł4 and it sits almost flush with the dash so looks (almost) OEM.
No interference either. ![]() |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1317 ![]() ![]() ![]() |
have a look at this thread - i had exactly the same issue and fixed it with a choke mode filter
http://www.defender2.net/forum/topic32439.html?highlight=choke |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2788 ![]() ![]() |
this blue sea one, although not the cheapest, fits in the exact same hole as the standard 12v socket in the front dash, and has the same connections at the rear
![]() http://www.mudstuff.co.uk/products/electri...ocket.html Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3496 ![]() ![]() ![]() |
That looks like a great bit of kit. Children were just asking how to charge the iPads in the vehicle. 1951 80" S1 2.0
Not fitted mine yet (haven't got the car yet!!) but have offered it up to the facia and it fits beautifully.
And at 2 x 2.1A will handle 2 iPad/iPhones at full power. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
SeaIt is a Blue Sea one. a filter is next on list to try and fix. Its never over in my land rover.
If you're saying it a blue sea one you have then I suspect a fault, as they make great stuff.
Or maybe wire is excessively close to aerial? Or you have slightly pulled the aerial out of the back of the radio? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6013 ![]() ![]() ![]() |
I too have a blue sea one fitted to the side of my mud stuff dash pod (td5). When I have a phone on charge the radio signal drops off. As soon as I unplug the phone all is well.
I have a cheap twin USB into a ciggie socket just below the blue sea one and that is fine - no interference with the phone on charge, Both off the same power feed. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
