Home > Puma (Tdci) > Deep water prep.
DaftOldGit
Deep water prep.
With older Defenders, it was quite a straight forward task to prepare the motor for deep water wading, but the TDCi has all manner of added electrics.
Is this a concern?
Is there anything necessary besides the usual fitting of plugs in drain holes, extending breathers and raising the air intake?
I want to be able to tackle flooded roads without any worries.
Post #490494 10th Jan 2016 12:57am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
If a road is that flooded you are worried about being above the limits of a standard defender waiding level I would suggest not to drive it, there are many hidden dangers from submerged trees/vehicles to missing drain covers not to mention the fact you can't see where it is road or ditch.
I know this doesn't answer your question but it is what I would advise. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #490496 10th Jan 2016 1:03am
RobKeay
Biggest problem with tdci is the air in take. It seems to to suck water in. There are quite a few threads on how to seal it.
Post #490500 10th Jan 2016 1:33am
jst
there are some good kits out there to seal it in one go to a snorkel too. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #490660 10th Jan 2016 6:20pm
Treebeard
United Kingdom 2005 Defender 110 Td5 CSW Chawton White
Have a look under the left hand rear wheel arch at the back and check that the fuel tank breather hasn't perished and split. It is in the firing line for spray from the rear wheel.
Post #490733 10th Jan 2016 9:05pm
jst
to be fair that would be extended with the breathers, or at least it should be, good point to highlight though. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #490759 10th Jan 2016 9:45pm
JR
Scotland 1984 Defender 90 200 Tdi SW Coniston Green
Speaking as someone who has already drowned a 2.4,
ECU behind cylinder head
ECU under driver's seat
Central locking door activators & main controller
As above for electric front windows
Heater motor
All fuses & relays needed connection cleaner to make them work
The above needed changing!
Axle breathers, especially rear!
Transmission breathers
Even if snorkel fitted, airbox & filter likely to get soaked!
Fuel tank breather very susceptible to splitting making it an easy access point for water in the fuel! Symptom of split: fuel spill from under vehicle when necking the tank at the pumps
In addition the rear diff & transfer box had to be replaced due to water damage
The above was from a 110USW but is unlikely to be the full list as incident was 4 years ago but gives you an idea of what resulted from a dunking.
Post #491045 11th Jan 2016 4:49pm
g-mack
how deep were you? My 109 thread
my youtube channel
Post #491083 11th Jan 2016 6:17pm
JR
The water itself wasn't that deep, maybe 2-3feet and the burn wasn't very wide but was in spate. When I lost traction at the far side, I tried to reverse back only to have the vehicle turn through 90degrees and float backwards down the burn until a tree stopped us.
We then acted as a dam resulting in 3 very wet bums and dammed water just about up to the wipers on the outside and just below the radio on the inside.
Extracation came about 3.5hours later when the level had dropped below the bonnet. But trying to get a shackle onto the towing eye on the bumper was very difficult, you know that bonnet hump is a lot bigger than you think as I could barely reach the towing eye! A rather large tractor towed me out in its lowest gear which is 8l00dy slow!
Repairs cost about £2000 plus the heater, rear diff and transfer box which were changed through 'more official channels'.
Post #491118 11th Jan 2016 7:14pm
mse
Thats more when and how things can go wrong.
Waterproofing to move through water around and or slightly above wading depth and preparing to sit in water not moving are two different things. Mike
Post #491124 11th Jan 2016 7:22pm
Puma air boxes are not sealed when built, the airbox actually has drain holes, take your air filter out and have a look Shocked
Post #491211 11th Jan 2016 9:54pm
mse
all LR airboxes are like that - my 300TDi disco has sealant to seal it - the problem you then get is any water that gets in, cant get out and ive had a small puddle in there before.
So if sealing watch out Mike
Post #491219 11th Jan 2016 10:12pm
