![]() | Home > Technical > What hose is this please? Puma 2.4 |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 925 ![]() ![]() ![]() |
Hi.
Looks like the Air Con hose, They are swaged unions you are referring too, It could be redone if you have the machine to do it but really it'll mean a new hose and then having the system re gassed. |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 334 ![]() ![]() ![]() |
Indeed it is the aircon hose, it's an expensive one to replace @ about £150 +vat. Part no JUF500320
To replace it you need to get the system degassed and then remove remove the engine ecu for access to where the pipe is connected to the a/c evaporator. The pipe is a single assembly from the joint you show to the compressor inlet. |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5098 ![]() ![]() ![]() |
what makes you think its leaking?
does your AC still work? Mike |
