Home > Maintenance & Modifications > Rear Door Hinges
lonewolf
United Kingdom 2010 Defender 90 Puma 2.4 CSW Zambezi Silver
Rear Door Hinges
This may have been covered before but I need to know: if you were to unbolt the rear hinges are the nuts loose or are they captive and hence won't disappear into some void in either the door or the bodywork recesses?
Post #490304 9th Jan 2016 5:20pm
Screbble
None of mine were captive when I changed for s/s (with ceramic paste) however all were easy enough to get at with a spanner/socket.
A little helper would make life easier.
Post #490305 9th Jan 2016 5:27pm
lonewolf
Cheers, thank you for the info Thumbs Up
Post #490313 9th Jan 2016 5:46pm
Cupboard
They just bolt through the door, you can see them on the inside!
Post #490316 9th Jan 2016 5:52pm
lonewolf
Thanks again Cupboard, I did go and have a look after the rain stopped and saw the door bolts, I/ll have to remove the trims to get to the nuts behind the bodywork. Thinking of getting some Optimill hinges.....maybe Razz
Post #490379 9th Jan 2016 8:21pm
