Home > Puma (Tdci) > Back to the Dealers Again
Page 2 of 2 <12
mse
LRE often say a similar thing, its not a ground clearance issue as such its a few other factors...there are some places on the Experience course a defender always hits where a disco doesnt. Mike
Post #4893 23rd Nov 2008 8:30pm
jst
the few factors others being>?
having used a D3 extensively off road (less Snow) i do rate them very highly, a descent set of Mts on a D3 and i beleive it will out perform a Def on the same tyres Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #4896 23rd Nov 2008 10:08pm
mse
Thats almost like a red rag to a bull Razz
Ill rate a defender over a disco any day...i will say TR is brilliant if you can drive off road. Mike
Post #4898 23rd Nov 2008 10:20pm
jst
each to their own then i suppose if you dont want to go into it! Razz Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #4902 24th Nov 2008 8:48am
TJ101
MM,, interesting debate re D3 to Defender off road
OK, not a D3, but a RR Sport , close enough, and have used both off road a fair bit
Put the Sport on MT tyres, and just as capable as the Defender, on occasions more so mainly due to the advanced electronics,
Back on Topic, sorry to hear more woes for Defender, but !! mine is still spot on, no troubles, Been thinking of ordering its replacement, but maybe the devil you know Whistle California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #4903 24th Nov 2008 9:34am
mse
You see, just because i love the RRS i wont argue Razz but i think the defender can do things it cant, but i love the RRS so fine! Mike
Post #4928 24th Nov 2008 6:05pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Defender is due back from the dealers tomorrow. Problem this time was a faulty fuel regulator, was suppling too much fuel at times and causing erratic engine noise.
The engine light came on a few times after start up and engine would rev a bit sometimes even with my foot off the trottle.
Fingers crossed thats my last trip to the dealers ! As I wont be going back for the 8th time for warranty issues . Next stop will be the Toyota Dealers Laughing
Post #5614 18th Dec 2008 7:54pm
Grockle
Let's hope it's ok when it returns Nidge. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #5620 19th Dec 2008 11:44am
markalpha
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
Could be the solution Nidge I did the same and did alot of trouble free miles in a Hilux Dc but it never felt the same as a 110 and not as good off road. Tell LR about your Toyota option it may get their ass in gear and sort out your problems. Good luck
Post #5624 19th Dec 2008 12:16pm
tcqf
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
now just how you feel,2 clutches,2transfer,new steering pump,still leaks water into the cab,rear windows dont stay fully up,2 axle oil leaks,doors dont fit theres a huge gap on the a posts,return fuel pipe in correctly routed,vacuum pump oil leak,paint problems,headlight surrounds rusted also door and bonnet hinge fixings rusting,central locking only works 3ft from the truck if you try in several different spots, i bought my 08 110 utility for work not realizing that it had registered a station wagon not an lgv so twice the road tax,still fighting dvla ,i ve always had a land rover but this has made me think ! i run transits they ve had vacuum pump and clutch problems since the puma engine came out in 2000 we chuck the dual mass flywheel in the bin and go back to solid ,no more clutch problems.
Post #205918 27th Jan 2013 3:36pm
K9F
^^^^ Shocked Any good news to be had? Shocked ^^^^
At least the sun shone today! Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #205924 27th Jan 2013 4:14pm
Blaserman
England 2011 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
How about:
10 rear diffs (2 of which have been 4 pin diffs)
2 Transfer Boxes
2 Clutches
4 Pairs of Half shafts and drive flanges!
Oh and a central locking failure with the need to sound the Censored alarm at silly o'clock in the morning after opening the doors!!! All in two years and less than 25k.
The engine seems to be the only thing behaving itself (touch wood) and now the diffs are on back order for god knows how long!!!! Evil or Very Mad
As for the D3/D4 off road debate they are awesome however they are designed to be driven by people with no idea how to drive off road (Clarkson) and they are just to damn heavy!
Post #227890 16th Apr 2013 7:13pm
Page 2 of 2 <12
