![]() | Home > Maintenance & Modifications > light bars, spot lights, Mounting without Drilling / wiring |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
IIRC D44 used to do a clamp on light bar. Couldn't find it on the site the other day but maybe have a look.
Cable routing, a RAI or Snorkel is ideal to route them if you have one? |
Mean Green Member Since: 15 Sep 2011 Location: South Ayrshire Posts: 280 ![]() ![]() |
You can get clamp on bars and cables can be run up behind the door seals without needing to drill anything. At most you might need to take a little 'check' out of the corner of the door pillar but it is hidden by the seal and if you are really worried about leaks a spot of silicon will seal it up.
The cable comes out of the front corner of the door just at the gutter and on to the bar. very little exposed wire. |
Nakatanenga do a stainless steel light bar which clamps onto rain gutter, powder coated one here
4 brackets for lights plus a bracket for an aerial Brendan |
DuncanS Member Since: 07 Dec 2013 Location: Cumbria Posts: 299 ![]() ![]() ![]() |
Cheaper one here. http://www.johncraddockltd.co.uk/accessori...mark.html. The Nak one is likely much better depending on your budget. North Cumbria Search and Rescue - Team Leader
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3855 ![]() ![]() |
Hello
Both thank you ^ I actually prefer the unbranded one without a motif even if that would be better long term? At £55 On a black Defender it should almost blend in, It would need some black caps over the bolts, I did notice the 'posh'one seems to have holes either ends for the cables... Will look at lights and have a think. I guess you have to drill through somewhere to get the cables in? |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7930 ![]() ![]() ![]() |
I don't know if it will help or if you have seen it already but MCMA1 thread shows an awful lot of wiring information he has carried out.
http://www.defender2.net/forum/topic40056.html |
^ Eeek,
He looks like he know's what he's doing as well, Looks great but a lot of wires.... ![]() |
