Home > Technical > Bulkhead
Vipergts
Bulkhead
Looking at a 110 2008, Where on the bulkhead should I be looking?
Is it easily seen if rusty?
Post #489742 7th Jan 2016 9:38pm
DAZ110
Around this area is sometimes rusty:
Post #489756 7th Jan 2016 10:04pm
Retroanaconda
Indeed!
Post #489782 7th Jan 2016 11:13pm
DAZ110
...and that's a 2015 model Defender I assume....! Wink Whistle Laughing
Post #489785 7th Jan 2016 11:17pm
Vipergts
Ah....OK thanks
I thought it might be down low
Post #489799 7th Jan 2016 11:41pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Check the footwells inside and out
I always take a mot corrosion hammer and give areas a few taps
Doesn't do any damage but I would ask permission of the owner first if he insists you don't use it be careful as he may know more than he is letting on, also a good pair of gloves and a torch is great for checking the bulkhead, with gloves on gently prod with your finger suspect areas. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #489829 8th Jan 2016 2:13am
Retroanaconda
Nope, but it's what one might look like in 2027-2030 by the rate of that ones decline.
Or likely sooner.
Post #489852 8th Jan 2016 9:20am
Cupboard
How do you stop it corroding up there? Has that come from the inside out or the outside in?
Post #489936 8th Jan 2016 2:05pm
Mash
Some water can enter where anything is bolted on so windscreen hinges, door hinges etc. The only way to stop it is liberal amounts of cavity wax followed by more with a little more after that, then regular top ups.
When I did a bulkhead swap on Jas I had the bulkhead at every angle filling it up with cavity wax to ensure a good covering. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #489942 8th Jan 2016 2:16pm
RRUK
Centre area rarely rusts due to oil leaks and it's not in the zone of mud and water splatter.
Door pillars and top as shown above are key areas. If you see slight rust marks in the paint coming through, it's a bad one. Walk away 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #489999 8th Jan 2016 6:19pm
