Home > Maintenance & Modifications > Comfier suspension options?
Page 4 of 5 <12345>
Alive Tuning
Hi All
Tim is right! Gary and i have decided Alive is going to develop some comfort springs for the 110. not saying they will be available right away but keep an eye out as they are on the way!
Alex Divers Thumbs Up
Post #489220 6th Jan 2016 3:43pm
g-mack
Post #489223 6th Jan 2016 4:00pm
Allan c.
France 2009 Defender 110 Puma 2.4 XS CSW Zermatt Silver
That's good news!
Will they compromise the defenders towing ability?
Post #489275 6th Jan 2016 6:21pm
Biffas
England 2014 Defender 110 Puma 2.2 USW Corris Grey
At last i can see light at the end of the tunnel thanks all at alive tuning from Luke. 2014 110 USW.
Post #489321 6th Jan 2016 8:45pm
YOLO110
Australia
Just wondered if you clever guys at Alive are able to offer your 90 'comfort' springs without having to drop the ride height the 1.5 inches? I would love the more complaint set-up but without losing the ground clearance so often required in Australia off road. Thumbs Up YOLO... You Only Live Once...
Post #489386 6th Jan 2016 11:08pm
nitram17
Alive Tuning wrote:
Hi All
Thats great for the 110 owners as i have mentioned before i dont want to lower the ride height of my 90 so would it be possible to fit your comfort springs with some spring isolaters to maintain the height.......as i want the better comfort ride and i am not bothered how fast i can take a corner!Perhaps you could manufacture some spacers yourself and improve sales of your comfort springs amongst the non boy racers !
Post #489399 6th Jan 2016 11:32pm
Morepower
New Zealand
I've looked at this issue for both the 90 and 110 and could design some adjustable spring platforms, so you can run std or lower ride height..
Whats everyone opinion?
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #489442 7th Jan 2016 1:38am
McGeordie
United Kingdom 2014 Defender 110 Puma 2.2 USW Montalcino Red
Adjustable ride height...now that would be cool! Sold Def 90 HT 2010...Stornaway..(SOLD in Oct 2014)
Current: delivered October 2014:- 110 USW XS.....Montalcino Red
Post #491099 11th Jan 2016 6:39pm
Green Machine
Alive 90 Comfort Springs
Well I have now had Alive's comfort springs fitted to my 90 for a week, so thought I would feedback some initial impressions. There is no doubt that ride quality is significantly improved over the standard 90 CSW setup. The difference is most noticeable over smaller bumps, particularly rumble strips, cattle grids and level crossings. Previously these would all send a considerable vibration with associated clattering and rattling through the whole vehicle, now they are barely perceptible. I had the springs installed with genuine spring isolators top and bottom all round, so some of this effect may be coming from the isolators rather than the springs. The main reason for fitting the isolators was to regain some of the ride height lost with the lowering springs. I'm very pleased with the resulting 'stance'. It's a touch lower than standard, but you'd struggle to tell and it now sits perfectly level (previously slightly nose-up).
Handling is largely the same as before. There is maybe a touch more roll through fast corners, but very difficult to tell. Mine has standard ARBs front and rear and at the moment I certainly don't feel a need to upgrade the rear ARB.
Overall Alive's comfort springs are very well judged. They really do take the edge off the harshness, but still retain a good degree of firmness in terms of handling and body roll, which is probably quite a difficult balance to strike. If you soften the ride right down to give great comfort, you increase body roll and reduce handling performance. Firm it up to get the handling back and you lose the ride comfort. These are a great balance of the two.
It is worth mentioning that the ride is still on the 'firm' side - it's certainly no Rolls Royce! Bigger potholes and bumps still upset it as they always have, but I suspect this is down to the characteristics of beam axles and the fundamental suspension system, which we all recognise is some way off a modern car's all-round independent suspension. All in all I think this is probably about the optimum setup for a 90 that spends most of its life unladen on the road (as mine does).
Also worth mentioning that mine is a 2005 Td5 and has done around 55k miles, the springs removed were the originals so probably a bit tired. I am running Koni Heavy Track shocks set to their softest setting (both before and after the spring change). 2005 Td5 | 90 Station Wagon | Tonga Green
Post #498659 31st Jan 2016 5:00pm
Biffas
I wish alivetuning would hurry up and do the 110 setup my wife refuses to sit in the back of mine my poor 7 year old son loves to sit in the front.
Post #499246 1st Feb 2016 8:14pm
RRUK
Re: Alive 90 Comfort Springs
Thanks for the write up.
If I go down this route, I will probably fit the Bilstein B6 dampers too, and leave the ARB's as standard.
I will also do a write up, but as I'm away a lot over the next month, it won't be till March or April. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #499347 1st Feb 2016 10:40pm
Alexke
Belgium
How hard is it to do a Air suspension conversion on a Defender?
cant we just take the gear of the P38? or am i Completely wrong? Discovery 4 SDV6 Landmark
F31 320dA Msport xDrive
LR Defender 90SW TD4 Stornoway grey
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #499406 2nd Feb 2016 1:33am
Alive Tuning
We are working on it at the moment Thumbs Up
Post #500238 4th Feb 2016 10:51am
RCMike
An option that i'm currently using is a set of Terrafirma front light duty +2's springs on the rear of my 90. They are 200Lbs spring rate and approx 39/40cm uncompressed. I regain ride height with some spacers.
They provide a nice rate reduction over standard but not too soft.
Post #500629 4th Feb 2016 10:15pm
Defenderdredd
England 1992 Defender 110 Td5 Black LE Java Black
Would be interested in 2 sets, both for 110 Double Cabs, shocks as well! Very Happy
Post #500653 4th Feb 2016 11:11pm
Page 4 of 5 <12345>
