![]() | Home > Td5 > How to check which paint I have? |
V8_Disco Member Since: 19 Dec 2015 Location: East Yorkshire Posts: 37 ![]() ![]() |
The 100% way is to get a paint shop to use a light gun and look up the paint code ... Mine is a nor quite right bonatti grey ... In reality it's a GM paint that's been badly applied
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
You should have a paint code on your vin plate, then you can cross reference it with this..
http://www.dingocroft.co.uk/acatalog/paint8.htm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6041 ![]() ![]() ![]() |
Or call the local dealer and ask them ? 1999 Defender TD5 110
http://www.landroverresource.com/
Download a rave for land rover from here. Put it in a virtual drive and set your computer date at the date off the file. With your Vin number you can find the build spec etc. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6725 ![]() ![]() ![]() |
2004 is probably Zambezi, if I remember correctly Zermatt didn't come in until later (2006/7)
I think my old 90 was Zermatt, that was 04, as I assumed it was Zambezi.
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1791 ![]() ![]() ![]() |
I have the original sales receipt for mine, it's genuinely the only place it's recorded!!
MGDM4 Member Since: 28 Aug 2015 Location: Leeds Posts: 45 ![]() ![]() |
Thanks guys.
![]() Would anyone be able to say where the best place is to buy a genuine LR colour aerosol can from? Thanks Matt |
You could try Dan at Duckworth Land Rover. 1999 Defender TD5 110
Freypal Member Since: 23 Sep 2013 Location: Shropshire Posts: 271 ![]() ![]() ![]() |
My 06 td5 90 is Zambezi. Paint code is shaped on the vin just have a look at that to confirm.
Dan will also be able to tell you the colour from the VIN number, it's in the build spec.
You should also be able to plug the VIN into the JLR TOPIX site and get the colour back: https://topix.landrover.jlrext.com/topix/index If you don't want to faff with registering etc PM me your VIN ![]() ![]() ![]() |
