![]() | Home > Technical > 2.4 Tdci odd noise at 2900-3000rpm |
Check security of intercooler hoses, clips and for evidence of splitting. Also check your Catalytic convertor heatshields for security too.
![]() Treat every day as if it is your last....one day you will be right!! |
N16kct Member Since: 24 Aug 2015 Location: Oxfordshire Posts: 151 ![]() ![]() ![]() |
Thanks for the pointers, I'll do this tomorrow when I remove the fold down steps and report back. Hopefully something simple for a change
furianer Member Since: 06 Feb 2011 Location: Coomberdale Western Australia Posts: 27 ![]() ![]() |
This is what i got. in one of my customers defenders, any similarities to yours This has done 214 ooo km power is sort of still ok, no crankcase pressure, no oil or water usage Richard |
Oldyellar Member Since: 04 Sep 2015 Location: Central Posts: 415 ![]() ![]() ![]() |
Is that no the hydraulic cam lifters worn out?
Noiseydave Member Since: 27 Dec 2015 Location: West Midlands Posts: 43 ![]() ![]() ![]() |
Hi
We had similar on a well maintained 2007 150k example. Turned out to be camshaft, lifters badly worn and timing chain tensioner. There was also debate about oil pressure but I cannot remember if they changed the oil pump. Dave |
This is the source of the noise in our case
haven't checked timing chain or tensioner |
