Home > My Defender > It's not a Jeep! (110 TD5 CSW)
Page 2 of 4 <1234>
Cupboard
Thumbs Up
Love that 110.
On the list of Defenders I wouldn't mind owning myself Smile
Post #487249 31st Dec 2015 2:04pm
miker
Thank you for the kind words! The old beast seems to be garnering quite a bit of fondness on here!
The last couple of days didn't quite go to plan. Pulled up at home to the strong smell of diesel, looked underneath and I kid you not there was a stream running off the diff case. The source of the leak was the hose that runs to the front of the block from the FPR. It was more of a sprinkler than a hose! Sourced a replacement, huffed, puffed and cursed in the dark to get it swapped over, and hopefully it should improve the running, as I suspect that was there all along, just not quite as badly.
Either way, a picture of the new face, with wipac crystals, clear LED sidelights and Wipac spots on the bumper.
20151231_132717 by Mike Redgrave, on Flickr
Post #487492 1st Jan 2016 1:25pm
L110CDL
Looking good there Miker with the new front additions, glad you got your problem solved Thumbs Up
Post #487632 1st Jan 2016 9:15pm
miker
Damn and Censored .
Went for a run today with Matt (MGDM4) to compare how mine was running compared to his standard TD5.
We did manage to confirm that it's still quite down on power. Then there was a thud, then there was no power, then all the oil escaped through a hole in the timing case. Now it's broken.
Looks like the timing chain has let go. Apparently that only really happens when the engine isn't built correctly, and someone doesn't loctite the the oil pump sprocket retaining bolt. I won't know if that is the case until I have a look inside, but the engine in it was a recon that has only done 21000 miles!
Thanks go to Matt, who tried to get me recovered, unfortunately his recovery company were less enthusiastic. Tom and his exceptionally quick puma, who happened to drive past and gave me a tow, despite never having met before! And finally to a friend of mine who came out to tow me the rest of the way back to his house, where my defender currently resides until I figure out what to do!
Post #490453 9th Jan 2016 11:00pm
JAY BOY
Wales
That not good news Big Cry
Theres always a silver lining though once you have sorted the engine you'll find something else that needs doing. Thumbs Up
Chin up its a keeper Wink
Post #490454 9th Jan 2016 11:13pm
miker
Hopefully whether I end up rebuilding or replacing, I should be able to find and cure the latent running issues!!
Post #490479 10th Jan 2016 12:04am
miker
Replacement engine sourced, and beasty recovered home from a mates house to get cracking on the rebuild.
20160116_140059 by Mike Redgrave, on Flickr
Here behind a friends defender, on another friends trailer! Defender owning friends are the best kind! I now have to endure much ribbing about this being the second occasion that my TD5 has been rescued by an old 300tdi!
Post #493546 18th Jan 2016 1:35am
Pilgrimmick
Maybe you should swap the replacement engine for a tdi! 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #493570 18th Jan 2016 9:05am
miker
The idea has been discussed! But I'm daft and stubborn and do quite like the td5 when it runs well!
Post #493611 18th Jan 2016 11:19am
miker
Brief update of the last ten weeks:
Sourced (in the end)
A replacement 15P TD5 engine, 5 injectors, a new flashable ECU, Fluids, gaskets and other stuff, Replacement lower rad hose (don't ask, on refitting it got wedged against the lower pulley. Didn't notice, rubbed through, water everywhere), Replacement thermostat (hot heater!) and many hours of labour (thanks go to my dad, luke off here and several friends)
Then this happened:
20160124_144419 by Mike Redgrave, on Flickr
Put it all back in to find we couldn't select any gears.
20160130_164805 by Mike Redgrave, on Flickr
The next day dropped the box to flip the clutch around (doh!)
Then this happened: (Hurrah!!)
http://vid391.photobucket.com/albums/oo359...abhwrr.mp4
Then spent some time tarting bits up and getting everything we took off back on. Went to dartmoor with my scout group over the easter weekend, so between shakedown runs at that I've been back on the road for ~1500 miles.
20160325_104055 by Mike Redgrave, on Flickr
Next jobs, driveline clunk, footwell leaks, speakers in the rear and sorting the doors!
Post #519062 29th Mar 2016 9:43pm
L110CDL
Good update, would of loved to have seen the pics to Sad Clayton.
Keeper.
Post #519309 30th Mar 2016 8:50pm
miker
Hopefully fixed!
Post #519327 30th Mar 2016 9:17pm
L110CDL
Many thanks miker Thumbs Up if you don't mind me asking, what part of Dartmoor ? Clayton.
Keeper.
Post #519389 30th Mar 2016 10:10pm
miker
Base camp was cockingford (Referred to by my old scout leader as the coldest camp on earth).
Groups were out on routes that cover a fair area, but covered Fensworthy, burrator, hameldown, princetown, two bridges etc.
Post #519427 30th Mar 2016 11:35pm
Cupboard
Your first Land Rover but you're already learning a lot about its innards :/
Still, so long as it doesn't let you down in a dangerous way with a load of Scouts on board it's all a learning experience.
Post #519510 31st Mar 2016 10:36am
Page 2 of 4 <1234>
