Home > Puma (Tdci) > Puma2.2 DPF delete
Mcd
United Kingdom 2012 Defender 90 Puma 2.2 HT Cairns Blue
Puma2.2 DPF delete
Had my puma 2.2 DPF removed but cat left in place.
DPF deleted in software running great but after 1200 miles and 5 weeks
The DPF regeneration light has come on.
Any ideas would be much appreciated.
Post #487014 30th Dec 2015 9:08pm
Jukathy
2012 Defender 110 Puma 2.2 SW Keswick Green
Good joke, man Laughing
2.2 equipped w/ DPF only. No cats under the car.
So dream along ... Jukathy
Post #487052 30th Dec 2015 10:25pm
2.2 has a combined catalytic converter and DPF if vehicle is to EU5 emission standards.
What physical work was actually done?
Post #487064 30th Dec 2015 10:35pm
Mcd
Dpf was cut open all bottom honeycomb removed, left cat in place at vert top, ecu reprogrammed deleting dpf.
Been running great not sure why regen light has come on after 1200 miles
Post #487096 30th Dec 2015 11:40pm
Jonno
United Kingdom 2011 Defender 90 Puma 2.4 HT Santorini Black
Did the person who did the work actually know what they were doing ?
It sounds like it's function has not been removed in the software. If it has and the dpf is still partly there it will surely block if it isn't set to regenerate.
Personally i think it's there for a reason and you have paid for it so why remove it the defender isn't a sports car. It's a 4x4 and a bloody slow one at that
Post #487104 30th Dec 2015 11:59pm
Did the person who made the software mods really understand what they were doing? There are very few people I would have confidence in to do this.
It will be interesting to hear what happens when/if the fuel strategy starts dumping masses of fuel down the exhaust to start the regen!
A bodged removal will give more trouble than a DPF ever would (why was it butchered in the first place, by the way?), quite apart from being illegal on the road.
Post #487109 31st Dec 2015 12:16am
Jukathy
Mcd wrote:
Dpf was cut open all bottom honeycomb removed, ...
Did u take pics from the honeycombs, man? Cause I cannot believe this.
Sounds still like bad jokes to me Mr. Green
Post #487111 31st Dec 2015 12:35am
Cuthbert
Re: Puma2.2 DPF delete
I'd like to understand the thinking behind undertaking this modification? It sounds all a bit 'experimental' to me, although I can see the appeal in not having a DPF (which in itself is a pretty crude solution to anti-pollution control).
Post #487115 31st Dec 2015 12:47am
WhiskyJackR
Kinda sounds like one of those hotel room operations where you wake up in a bath of ice minus a kidney!!! Any farther South and I'll need to trade the Defender in for a Landing Craft Smile
Post #487117 31st Dec 2015 12:53am
Jukathy
My idea: The DPF is still in place and sb tricked you very badly Neutral
Now just start the DPF regen anyway. Make the DPF light disappear. And you'll see ..
Post #487119 31st Dec 2015 12:58am
Mcd
The ecu was done professionally, the reason it was removed it's a slow farm vehicle that needed its oil changed every few weeks as flooded with diesel. Engine never gets that hot due to farms being only a mile apart. It spent more time in the dealers than at work
Post #487147 31st Dec 2015 8:48am
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
if the DPF has been removed - and for the others making unhelpful/sarcastic comments it can be removed as BAS offer this service - the software prob has a glitch.
If the vehicle still drives OK there should not be an issue as there is nothing to get blocked up.
Best bet give Pete at BAS a call he may be able to help
Post #487163 31st Dec 2015 9:44am
Jukathy
Done professionally? I can hardly believe that sb believes that the removal of the honeycombs really is professional.
Although I do still suppose that your 'professional' did simply remove nothing... ...you've been tricked, man, don't you see?
An EU5 Defender with DPF or an EU3 Defender without anything in the exhaust are professional - like Land Rover delivers it.
Why exactly did you buy an EU5 car from Land Rover? UK provisions? Your own environmental conscience as a farmer?
P.S. You don't need an EU5 approval for a farmer's. In the EU at least.
Post #487166 31st Dec 2015 9:50am
If the software modifications were done by a professional (someone of the calibre of BAS) then get in touch with them, since they will know what was changed and how much of the DPF monitoring and regen strategy software is still present. If the regen light has come on, it seems likely to me that either (a) the ecu has received a false 'DPF blocked' sensor input, (b) has attempted a regen which (hopefully) cannot take place, or (c) has erroneously turned on the light but done nothing else.
Whilst I do now understand why you had the DPF removed I fail to understand why you didn't remove the cat at the same time leaving a clear exhaust. I know the cat and DPF are a single physical unit but are you sure the innards are discrete?
Given also that there are probably many 2.2 Defenders which operate under similar conditions (farms, quarries, etc) apparently without problems I have to wonder if there was an unresolved malfunction with your particular vehicle, causing frequent regen attempts, which may still be present.
Post #487182 31st Dec 2015 10:39am
AndrewS
Was it Doctor Nick
 130's have feeling's as well you know Smile
Post #487194 31st Dec 2015 11:12am
