Home > Wheels & Tyres > Tyre pressure for defender 90 td5 with 235-85-16
hugh_b
Hi guy's, I currently have the standard general tr tyres fitted on my defender 90 csw. What are the correct tyre pressures for 235/85/16 tyres on a 90 (non loaded)?
My manual only gives tyre pressures for a different size tyre for the 90.
Thanks
Hugh
Post #48659 15th Dec 2010 9:59pm
Lorryman100
There are a few posts on this subject, try a search Thumbs Up
I run mine on a puma 110 at 30psi front and 35 psi in the rear empty up to 45 psi when towing.
Post #48666 15th Dec 2010 10:19pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
The correct pressures are 28 front and 38 rear but most people find these dont suit.
I run mine at 30 front and 35 rear most of the time changing to 28 front and 32 rear for greenlaning with no load and 30 front and 38 rear for towing long distances.
Pete.
Post #48671 15th Dec 2010 10:56pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
i tried loads of combinations on my 90 with both HD and standard suspension at the rear and with TRs and BFG ATs.
i have am now on the BFGs and with standard rear springs and prefer 30 front and 38 rear, 35 or less is a bit bouncy on the side walls....... Confused BM52
Post #48678 16th Dec 2010 12:22am
MK
30 PSI ALL FOR DIRT ROADS
35 FRONT-38-REAR ON LONG TRAVELS IN THE HW FOR FUEL SAVING.
LOADED FOR ME ARE 4 PEOPLE AND CAMPING STUFF IN THE BACK.
OTHERWISE BOLTS AND TEETH START TO FALL DOWN. Puma 110" SW
Post #48690 16th Dec 2010 9:53am
C90
Thanks for the info here chaps, still useful after 14 years :thumbs-up:
Bumping it for anyone else looking.
Post #1052854 25th Nov 2024 10:00am
I use (PSi) 32F & 36R, that’s with 255/85/R16.
But I used to use the same with 235, if you tow heavy then you might want a bit more in the rear. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1052858 25th Nov 2024 11:27am
Bluest
I'm going to be the killjoy fun-police here, but I'd just caution against running pressures on the road substantially different than what the manual says. The factory pressures will have been chosen for a reason. Comfort is only one factor. Tyre life, handling, wet grip etc are all part of the mix. An issue introduced by running a different pressure may not become apparent until you have to make an emergency manoeuvre and could result in the car rolling rather than sliding, or under/oversteering when it shouldn't, aquaplaning/skidding more easily, heat build-up leading to tyre failure and so on.
I'm not saying you'll definitely die in a ball of fire and a couple of PSI here or there probably won't make any difference, but tyre pressures do play in important role in vehicle safety. 2007 110 TDCi Station Wagon XS
Post #1052862 25th Nov 2024 12:19pm
revd
f28/r38 (BFG AT)
Ran with this for 200k miles- seemed to work just as well at 83mph on the autoroute and three up with camping gear, or solo on snowy tracks
Post #1052864 25th Nov 2024 12:43pm
Chicken Drumstick
Cobblers. If it was a 'real' issue, there would be legislation around it. And there isn't.
Sure a flat tyre is still a flat tyre. But there is a huge array of usable pressures depending on use, surface, driving style and the actual tyres you are running.
Post #1052878 25th Nov 2024 2:57pm
TexasRover
Not 100% sure but are things like tire pressure monitoring not becoming a requirement together with all the other nanny (making money) schemes.
The Governments are pushing all this technology out for safety and environmental reasons and the manufacturers are loving it.
Post #1052882 25th Nov 2024 3:15pm
C90
Rolling with laughter
I was going to go with something along the lines of what Zinke is saying "30 front and 35 rear" which is very close to the factory recommendations - 28 front and 38 rear
I'm running Continental Cross Contact 235/85R16's on a 2007 Puma.
Post #1052883 25th Nov 2024 3:17pm
Bluest
I don't want to get into to an argument, obviously, you can set your pressures to whatever you want. But, as the drivers/owners we aren't in possession of the full facts as to why a given pressure is specified and where the threshold is for things to become dangerous when you deviate from that.
By way of an extreme example. A long time ago now, but there was a serious issue with tyre failures leading to rollovers in American Ford Explorer SUVs. Firestone argued that had the specified tyre pressure been 4 psi higher the tyre failures would not have occured.
As I said, I'm not stating a couple of PSI will be life or death, but I read of people running 110s at 8-10psi under the factory rear tyre pressure for reasons of comfort which for me is pushing it too far. My question is why did LR set it at 46psi or whatever it is? It isn't for heavy load/towing as there is an even higher pressure specified for that.
Once off-road, and speeds are much slower and grip with the surface is lower, go to town on lowering pressures. 2007 110 TDCi Station Wagon XS
Post #1052923 25th Nov 2024 6:45pm
revd
I run my 110 HT rear at 10 psi below factory handbook pressure when unladen - I was given the ok by the LR suspension engineer who signed off the tyres on Td5/Puma Defenders after extensive testing at Michelin's test track. (he also adjusted my steering box and centred the steering rack, I paid in beer)
Post #1052944 25th Nov 2024 9:56pm
Chicken Drumstick
Don't be fooled. TPMS (Tyre Pressure Monitoring Systems) are NOT there for safety..... it is an EU lead stupidity on emissions. And is not present or mandatory in other World markets. The idea being if a tyre is flatter, it will increase drag and reduce mpg and increase emissions.
Some implementations are terrible, such as on my Jimny where less than 1 psi below the programmed level lights the dash up like a Christmas tree and will prevent the dash showing you anything useful until you put 0.8psi of pressure back into the tyre.
Post #1052978 26th Nov 2024 10:35am
