![]() | Home > In Car Electronics > Rear view camera wiring |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
Use one of these to connect into reversing lamp and connect two bare wires to your camera.
http://www.mudstuff.co.uk/products/electri...-loom.html |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 602 ![]() ![]() ![]() |
Thanks for that Romadog, looks a neat solution for the connection.
My problem is more how do I get the wires that are now in the car, exiting from behind the rear speaker panel out to connect them to the reverse lights or via that harness? |
Remove speaker panel on lhs and there should be some wires coming up through the floor via a grommet. Run wires through this. Remove reverse lamp and plinth. You should see your wires there.
OK, hoped that would be the answer. Could not get speaker panel out so only removed the speaker did fitting from there.
Had the "if I pull this any harder it will break" anxiety with the panel, is there a knack or just more force? Wondered if the window surround had to come out first? |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2064 ![]() ![]() |
Take the 3 clips out and with a bit of fiddling it will come out.
You will probably also need to remove the trim from around the small window that is above the speaker panel as it is fitted slightly over the top of the speaker panel. This needs a hard pull and it will come off its clip fixings. Last edited by DAZ110 on 29th Dec 2015 7:42am. Edited 3 times in total |
Great, thanks. That's tomorrow sorted then.
