![]() | Home > Maintenance & Modifications > Mod-free snorkels |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2788 ![]() ![]() |
Apologies if this is a repeat, but I couldn't find much on search of this site or google.
I've seen the Entreq snorkel but can't believe the price, and surely it can't be the only snorkel around that doesn't require any drilling of bodywork etc? Want to fit a snorkel to the new 110 and really like the genuine Land Rover / Mantec style but don't want to drill two rivnut holes. Any suggestions? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
i wonder if there is a way to fasten from inside on mantec plastic one, with threaded bar. My 109 thread
my youtube channel |
http://eshop.lmslichfieldltd.com/Snorkel-L...t-defender
this works at the bottom end and design the pipe work your self to be mod free i.e. bracket from behind wind screen hind and so on ![]() ![]() Last edited by dorsetsmith on 28th Dec 2015 10:18am. Edited 1 time in total |
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() ![]() Here's a few pics of one I made, no new holes were made I the fitting of this item ![]() |
The main bracket is sandwiched between the bulkhead and the std bracket, sealed with sikaflex, doesn't vibrate and seems very stable , it's also made from stainless and powder coated
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 ![]() ![]() ![]() |
@davidwhittaker, I am curious to know why you do not want to drill the bodywork? 1998 Tdi 90 SW,
2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT�s, Recaro CS�s, anorak, wellingtons |
thanks for all the info guys, does really seem like theres a gap in the market here that enter are trying for!
To me it should be incredibly easy to do, just need to sandwich a plate behind the normal vent hole and bolt through the snorkel face on the outside, through the existing holes. WildCard, i want to be able to return the defender to standard if needed, and don't want to leave holes exposed. Maybe ill just get a mantec one and try and sort something myself... I personally think theyre by far the best looking snorkel around Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
hi all,
see how the britpart one from Devon 4x4 attaches below: https://www.devon4x4.com/defender-puma-snorkel.html Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
also just found this: https://www.devon4x4.com/defender-300tdi-tds-puma.html
hadn't seen it before, maybe ill be able to do something with that. cheers ![]() Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20923 ![]() ![]() |
I'll be bonding the top mount on my Safari, like another member did.
thanks Steve, think ill bond the upper mount too - seems easy enough. Just need to pick something that won't remove the paint if i wanted to remove it! Cheers, David
I'm not worrying about that - can't see why I'd ever want to remove.
Here is a SS bracket, it's actually K9F's and I've borrowed it I'm sure he won't mind. I hope! ![]() Lower mounting I still say certainly needs proper fixing too, the screen frame though as most of us know is good for starting to rot! Also the OE bracket is PC'd mild steel. ![]() Click image to enlarge |
cheers Steve, good advice
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
I bonded my safari snorkel to the window frame with sikaflex, is used to bond things to the undersides of boats while still in the water. Its been on nearly a year now without budging, had to remove it for some warrenty work on the bulkead and the paint was fine underneat, just took a bit of scrubbing to get it off.
Just make sure you leave it a good 24 hours to set! I held mine in place with a ratchet strap to the roof rack while I was away for the weekend!! Is rock solid now!! |
