![]() | Home > Technical > Puma power loss - unusual squeal from turbo |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1856 ![]() ![]() ![]() |
The problem is that on mine at least the fault was intermittent, and yes generally after a long constant speed (fast) run and then a change in throttle opening.
First time on the run back up from the ferry at Portsmouth, didn't happen until Cheltenham turn M5, next time 3 months later, again virtually the same place again back from Portsmouth. In between times it was perfect. It slowly got more and more regular but I was swapping and checking everything else in the meantime. The only good thing is it will reset and shouldn't leave you stranded. If everything else above is tried, and the turbo variable vanes do feel 'sticky' you could try a turbo cleaner through it for a few miles and then try it for movement again, and again I believe all of the turbo parts are available, I was just so p155ed off by this point I put a new turbo, bigger intercooler, silicone hoses, straight through exhaust just to make sure.... BTW the new turbo was from Turbo Technics in Germany, brand new, no exchange �660 delivered. |
Do they never learn - after a series of faults with Turbocharger Actuator Arm Corrosion on Discovery 4, Discovery 3, Range Rover Sport, & Range Rover, JLR issued a service update to dealers in 2011: Issue: A customer may report a loss of engine power and/ or the Check Engine Lamp (CEL) may be illuminated. A Powertrain Control Module (PCM) fault code read may display a turbocharger boost pressure related fault as a result of a seized actuator arm. Cause: The actuator arm pivot points can corrode leading to full or partial seizure of the actuator arm mechanism. Action: Following diagnosis, if the cause of the concern is corrosion of the actuator arm pivot, turbocharger replacement is no longer necessary as a lower level part is now available from Caterpillar. |
v8bobber Member Since: 26 Aug 2012 Location: pembrokeshire Posts: 452 ![]() ![]() ![]() |
Thanks for all the info. I've have been flat out in work so will hopefully have a look at this after the weekend when I have a couple of days off.
Fingers crossed that the weather is better |
