Home > Puma (Tdci) > 2.4 Tdci on its last leg ? |
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 |
Sounds like split hoses or something leaking somewhere?
26th Dec 2015 7:03pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16960 |
Sounds to me like someone has replaced the TDCi with an 8-cylinder Gardner!
26th Dec 2015 7:32pm |
furianer Member Since: 06 Feb 2011 Location: Coomberdale Western Australia Posts: 27 |
Thanks scoobeenut
But no cracked hoses or external leaks. Anyone had a blown head gasket between bores on a 2.4, just crossed my mind Black wolf, it does sound a bit like a Gardner, but not as solid If a engine conversion ISUZU. 4bdt1t for me. |
26th Dec 2015 7:58pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1732 |
There was a post on here reference a potential egr cooler leak allowing the coolant to pressurize?
26th Dec 2015 10:51pm |
Ickle thanks, but a leaking EGR cooler wouldn't be responsible for this unhealthy noise
Here is another little clip |
26th Dec 2015 11:58pm |
Piston cooling jet fault?
27th Dec 2015 12:08am |
Eau02467 Member Since: 20 May 2015 Location: Glasgow Posts: 48 |
Cracked exhaust manifold?
27th Dec 2015 2:48pm |
had a bit of a look see this evening,
injectors leak off test, runs with the comp hooked up injectors out endoskop showed lovley looking pistons. bores. spray pattern and valves, expected a lot worse with this milage Valve cover off this could be the answer or at least one of them this little clip shows exhaust valve Nr. 3 cam lob and follower. hard facing worn off, follower out of round nice evening to all of you, thanks for all your inputs Richard |
27th Dec 2015 6:47pm |
