![]() | Home > Australia & New Zealand > Importing into NZ from Aussie |
| TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752
OR,, Buy one in europe, (or UK = RHD) and ship back with you
One from my local dealer here in Somerset,, spotted at Lake Taupo Click image to enlarge California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
| Chamois Member Since: 24 Dec 2015 Location: Wanaka/Chamonix Posts: 114
From searching the web it looks like a bit of a mission, I've only looked at importing from UK so far.
I wonder if it's easier from Aussie? |
| AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242
Hope the driver of the LR practices his parking a bit better than that in the NY. He'll end up on some bad driver website if not.
My nieces hubby recently imported a new 6cyl Ford ute direct from Oz with no probs that I know of but suspect he may have gone through a dealer. AlanH. PS. Don't forget a lot of UK and European vehicles have had loads of salt under them during even a short life. Be careful. |
Makes sense to import from Aussie, I better start looking! Cheers Winter's here, thanks goodness!
| LRNZ Member Since: 05 Nov 2015 Location: Auckland Posts: 27
As far as I am aware it is no easier to import a vehicle from Australia into NZ than it is one from the UK. The shipping will be cheaper but the vehicle itself will probably be more expensive due to their far higher vehicle taxes. The main rule of thumb is that it either has to be newer than 2005 or older than 20 years. That means you'd be covered for the bulk of the rules. What age vehicle are you thinking of bringing?
Hi,
An 05 TD5 DC would be ideal for what I need. Looks like they're fetching getting on for 40k in NZ. It's a small container which would be 2k + the import and handling cost. Winter's here, thanks goodness! |
| Juddy Member Since: 09 May 2013 Location: Queensland Posts: 63
Plenty of land rovers in Oz for you. 2010 Defender 130 HCPU
1991 110 RFSV PERENTIE www.landybitz.com.au |
