Home > Maintenance & Modifications > Labcraft Scenelite
Gazngoz
Labcraft Scenelite
Season's greetings all.
Santa bought me some Defender Tokens. I was toying with the idea of a scenelite s16 fitted as a rear worklight with the option of switching it through the reversing light switch also - yes technically illegal but if I isolate the workight and reverse circuits with a on-off-on switch I think it should be good.
Then I came across the s17 and s18 models. Anyone have any experience of these "cheaper" ( its relative I suppose) models or been able to compare the three.
A colleague has mentioned whelen perimeter lights as an alternative but other than finding the UK distributor I havent been able to find out much about these lights. Again anyone with any experience please ?
Thank you kindly
G
Post #485547 26th Dec 2015 4:38pm
Terryt
Hello mate I've got the cheaper one fitted as a side / camping awning light ,,it's very bright more than bright enough for the rear .
Terry
Post #485549 26th Dec 2015 4:40pm
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
Post #485566 26th Dec 2015 5:45pm
Gazngoz
Terryt
Fab mate, thanks for that a users feedback is always helpful
Mike_B
Thanks fella. I had found the UK distrbutors website but it didnt have the specs / features that were shown on the link you posted. Have you used the Whelen's ?
Post #485620 26th Dec 2015 8:13pm
Mike_B
Here's the details:
http://www.whelen.com/pb/Automotive/Produc..._Light.pdf
They're good. I have both the Whelen and the Labcraft. Whelen have been going for donkeys years and produce 90% of emergency services vehicle lighting. Their kit is tough and long lasting. I use it on emergency response vehicles.
The Whelen model is RRP £50 plus VAT. It's £32.50 at the moment.
Post #485643 26th Dec 2015 9:26pm
Gazngoz
Fab Mike thanks -so with your experience of these is one mounted centrally above the rear door going to provide a reasonable amount of light as a worklight ? I ask as I have seen various pictures of Defenders with two scenelites one mounted, essentially, at each rear corner. To be honest I'd rather just have the one light centrally mounted.
Sorry for all the questions but as I said personal experience of this kit invaluable. I am grateful for your time
G
Post #485695 26th Dec 2015 11:30pm
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
I have the S17 ( I think ) fitted to the rear of the 90. I didn't bother removing the window washer to fit the light centrally, I just offset the light and it works absolutely fine. With one light fitted it casts an excellent light behind the vehicle, I can only imagine that two will be like daylight.
The pic is from a post I done at the time, it's just switched through an older style Carling switch.
Post #485704 26th Dec 2015 11:48pm
Cupboard
I have the S17. It's very bright, more than adequate for working at the back of the 110.
Post #485706 26th Dec 2015 11:49pm
Mike_B
One of these lift would be sufficient on the rear of your vehicle. 1000 lumens is plenty bright enough. I had a Labcraft Scenelight mounted centrally and relocated the washer jet to one side. As you can see already the light is just as effective mounted to one side. Personal preference really. If happily use the Whelen one over the Labcraft one, which was about £100 when I bought it.
Post #485707 26th Dec 2015 11:50pm
Gazngoz
Gentlemen , thanks for all your help. Santa's tokens are burning a hole in my pocket now - now when do the shops open again ?? Smile
G
Post #485733 27th Dec 2015 12:44am
ericvv
OP, plenty of info and pictures of various Scenelite installations and light output in below thread. Personally I have one S17 centrally installed and that is plenty for my needs.
Eric
http://www.defender2.net/forum/topic32834-45.html You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #485741 27th Dec 2015 7:11am
Gazngoz
Thumbs Up Thanks Eric, I had seen that post which is what prompted my question about one light or two. It was going to get expensive if two lamps were needed Rolling with laughter
That's a very tidy rig you have there. Looks fab.
HNY,
G
Post #485756 27th Dec 2015 10:20am
Cupboard
If you're not putting it in the middle, mount it on the side away from the door hinges. That way when you're working with the rear door open it's casting a more useful spread of light and it's not all behind the door.
Post #486220 28th Dec 2015 2:34pm
Gazngoz
Good point thanks. I think I've decided on one Whelen PEL mounted centrally - I don't have a wash-wipe to fret about ☺
Talking about not having things to worry about does anyone know when the purple socket lead RHS rear appeared on the loom. I don't seem to have one on my 93 MY 90. It's hard to say because at some point the car has been re-sprayed and all the loom coming into the vehicle in the RHS rear got covered in overspray but I do know there are no "spare" unconnected plugs.
Thanks again,
G
Post #486229 28th Dec 2015 3:27pm
