Home > Td5 > Td5 anti roll bar
chinnus
2001 Defender 90 Td5 ST Coniston Green
Td5 anti roll bar
Hi there,
My td5 pickup 2001 didn't come with front or rear anti roll bars
I have found all the parts numbers apart from the following....
The bracket that mounts the bar onto the fuel tank and the bolts and nuts associated with it?
The front arb chassis to bar bracket and the nuts and bolts that go with that I believe 4 bolts in all?
Many thanks in advance and merry xmas to everyone
Tom
Post #485325 25th Dec 2015 11:39am
miker
Onto the fuel tank? Mine has no roll bars either, but the bracket plates are there for mounting it onto the chassis legs. From doing a mates last week, the bolts are m8x30mm or so. Possibly cheaper to just get some grade 8 bolts from a bolt supplier than from LR?
Post #485328 25th Dec 2015 11:42am
chinnus
Hi there, thanks for your reply.
Rear
On my neighbours 2.2 the rear arb mounts onto the fuel tank guard/surround with a D shaped bracket?
Kind regards
Tom
Post #485330 25th Dec 2015 12:08pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
That doesn't sound like a correct installation, but I'm not familiar with the late models...normally the D bushings on Defenders and pretty much every car I'm familiar with are attached to a solid point on each of the chassis rails. Perhaps your mate has an aftermarket tank protector which also utilizes the rear ARB bracket mounts concurrently?
The drop links are then attached to a dynamic suspension component, normally as far outboard as possible for max leverage....depending on thickness of the bar and how much roll you wish to contain.
I know my TD5 has all the D bracket mounts welded to the chassis, front and rear In case one wishes to install.
Patrick
Post #485342 25th Dec 2015 1:23pm
chinnus
Will take some pictures later
Post #485353 25th Dec 2015 2:11pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Your right the arb's mount using D shaped brackets underneath the fuel tank, this is for a 90, on a 110 there is brackets on the chassis.
Regards
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #485399 25th Dec 2015 6:54pm
Gav40
United Kingdom 1998 Defender 90 Td5 HT Chawton White
Hi, just done this mod on my TD5 and the rear brackets and bushes are smaller than the front ones and are availible from island 4x4 and mount into the rear chassis rails adjacent to the fuel tank, I just used some normal m8 bolts that I had to mount them. Pre TD5 rear anti roll bars used the same larger brackets as used on the front for the rear as well bar the smaller bushes. That as I understand it anyway.
Post #485400 25th Dec 2015 6:58pm
chinnus
Hi there I have go the pictures now.... I forgot to mention I am talking about a 90
This is where the ARB mounts on a 2.2 on the fuel tank bracket
This is what the bracket looks like on my TD5 minus the bracket and the ARB... My question is what is the part number of said bracket and would it reuse the existing bolts?
Thank you in advance
Post #489986 8th Jan 2016 5:56pm
Gav40
Hi, yes mine mounts onto the fuel tank surround the same as your first photo, I didn't explain very well in my previous reply!
The only part number I can find is a britpart one and is the same brackets that I used when I did mine and bolts to the same place.
Don't know if you can use the existing bolts you have but worth a try
Post #490169 9th Jan 2016 8:53am
Gav40
Post #490170 9th Jan 2016 8:56am
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Fitted anti roll bars to my 90 td5 today as it never had them from factory took me about 1&1/2 easy to do and has made a huge difference 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #490363 9th Jan 2016 7:29pm
chinnus
Thank you to everyone for their input on this thread... For refrence I have attached the part numbers I used to buy all the bits for my 90 2001 TD5 and the prices I paid...
Ball Joint for Anti-Roll Bar - For Defender, Discovery and Classic NTC1888 4 18.00
Washer for Anti-Roll Bar Pin - Defender, Discovery RYF500160 4 1.92
Pin / Bolt for Anti-Roll For Defender - Goes Through NTC1888 Ball Joint RYG501480 4 4.80
Washer for Anti-Roll Bar Ball Joint - Defender, Discovery WC116101 2 1.26
Nyloc M16 Nut for Anti-Roll Bar Pin and Diff Flange - Defender, Discovery, Classic (Comes as Single Nut) NY116041L 4 1.96
Defender Anti-Roll Bar Clamp, Also Fits Discovery 1 NTC6776 2 10.00
Rear Bush chassisx2
EGP1889
Front Bush chassis x2
NTC6828
Drop link bush x8
552819
LR DIRECT - best price
Front 4 bolts SH110351L , washer WA110061L and Nyloc NY110047L
Rear 4 bolts washer and Nyloc - still finding part numbers
cheers
Post #490919 11th Jan 2016 11:15am
