![]() | Home > Td5 > Patrs |
| takoon Member Since: 16 Oct 2013 Location: central Posts: 48
Hi, the second last letter is the modelyear code. All the letters before this tells you only what type of Land Rover you have and where its produced.
Ex.: 90,110,130, Defender, hard top pickup station wagon etc. The digits are the productionnumber. -99 Td5 90 CSW -09 Jaguar xk4,2 Portfolio |
| 4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 1000
Chassis number is stamped on the chassis, engine number is etched on the engine, gearbox is stamped on the gearbox. Check your owners handbook for exact locations. The VIN numbers are 17 digits long... The HA##### you listed is likely the last 8 digits of the VIN wherein the "H" typically refers to the actual model year.
You will need one of these numbers to properly select parts for your Defender. http://vindecoder.eu/land-rover Click image to enlarge Click image to enlarge Once you figure this out parts numbers for your specific model and year can be accessed here. http://www.allbrit.de/NAV.cfm?PAGE=356171&SPRACHE=EN 2020 range Rover Mk IV Autobiography PHEV 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
| patric Member Since: 12 Nov 2015 Location: vaxjo Posts: 9
So the imported numbers is the last 8 one.mine is salldhf582a640xxx its still a little tricky perhaps i am learning soon
Correct. 2020 range Rover Mk IV Autobiography PHEV
| VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512
You can use "CALVIN" the Vin Number calculator: SAL Manufacturer code: Land Rover LD Model: Defender (for early models: Ninety, or One Ten) H Wheel base: 110 inch F Body type: 4-door Crew Cab, export only 5 Engine type: 2.5 litre Td5 (EU5 spec) 8 Steering and transmission: Left-hand drive (LHD), 5-speed manual (LT85, LT77, LT77S, R380 or other) 2 Model year: 2002 A Assembly location: Solihull, UK 640XXX Serial number Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
When a parts supplier or catalogue says "from Y1234567"... That means yours is covered as it is model year "2" (2002) and the "from Y" means from model year 2000 on. Hope this helps some.
Merry Christmas 2020 range Rover Mk IV Autobiography PHEV 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
| ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105
Hello all, I join in the cofussion, since I never understood this numbers or when you write about plate number (probably because of been from another contry)
For example a web part says "Rear axle disc breaks suitable for the Land Rover Defender from LA930456." My defender Vin number is SALLDAM188 1A6B1228 How can I tell it will fit?? happy holidays Augusto Augusto Defender 110 TD5 2001 Discovery 4 TDV6 |
Land Rover started using the internationally recognized 17 digit VIN number system halfway through production models in 1983 and early 84. "A" was the first model year that they started using it (1983 & 84 MY) and B=1985 MY, C=1986 and so on. Yours is "1" because they needed to start over as the alphabet ran out they started using numbers instead of letters.
Presumably when the new Defender is finally built in 2016 or 17 (or whenever Gerry McGovern and his design team decide to get on with it) the convention for decoding the VIN will probably change again. The "L" in the number you listed refers to the year of build (1994) so when the parts suppliers lists "from LA930456" they are saying from 1994 Serial number 930456 to present. Since yours is a "1" which means a 2001 MY the part will fit. Hope this helps some? 2020 range Rover Mk IV Autobiography PHEV 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
