Home > Series Land Rovers > Power Outlets
Cheshire110
Power Outlets
The Series 3 (like I understand 1s and 2s have) has the red and black separate 'pin' style accessory power outlet.
Does anyone know where I can buy connectors to fit these? I want to wire up a USB port or something similar to power small devices.
I also understand these are not fused? Cheers, David
Post #484918 23rd Dec 2015 9:05pm
SailingTom
If you look up land rover military light its the best way to get something with that connector. I long term borrowed one and wired it to a potable 12v cigarette socket in a hidden portable box.
meant i could power a satnav, like you say only use it for small things though.
this is the only thing i could find with the socket. admittedly thats an expensive one, but they come up on ebay aswell much cheaper.
http://eshop.lmslichfieldltd.com/lamp
http://www.ebay.co.uk/itm/like/27188576660...mp;ff13=80
Post #484972 23rd Dec 2015 11:46pm
JWL
Why not just add one of these and then you can just plug your USB straight in. You can put it where you like. You could allways source a similar product from one of the forum sponsors, I'm sure Brendan(aka 4x4 Overlander) would be able to sell you one.
http://www.ebay.co.uk/itm/12-24V-LED-USB-C...SwjVVVu13F
Post #484973 23rd Dec 2015 11:52pm
TJ101
SailingTom wrote:
this is the only thing i could find with the socket. admittedly thats an expensive one, but they come up on ebay aswell much cheaper. http://eshop.lmslichfieldltd.com/lamp
Those are the unit that can with the series etc,, Certainly dear !!! I got 2 or 3 for Ł20 for the Series 1 back June ish time,,
As Tom says, they do come up cheaper that that link
Save a search for RTC4784 California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #484984 24th Dec 2015 12:15am
miker
If anyone has a pair of calipers and could measure, that looks like a 2mm banana plug may fit.
Post #484998 24th Dec 2015 1:24am
uncas
I'm pretty sure that there's one in my garage that I used in a Lightweight that I had yonks ago if I can find it you can have it. I'll not sleep now for trying to remember which tin it's in.
Uncas
Post #485000 24th Dec 2015 1:45am
Cheshire110
Thanks for all the advice, people. Spot on as usual!
Uncas, very kind of you. Let me know if you come up with anything and we can come to some arrangement. No worries if not obviously! Cheers, David
Post #485001 24th Dec 2015 1:49am
uncas
If I find it David you can have it for free its been there over 25 years I don't think that I will be wanting to use it.
Uncas
Post #485003 24th Dec 2015 2:07am
Cheshire110
Cheers, well let me know if you find it anyway and we can come to some arrangement if so. Very kind of you, thanks. Cheers, David
Post #485004 24th Dec 2015 2:28am
Barneyboy
England 1986 Defender 90 2.5 n/a Diesel ST Nato Green
Hi failing that I got mine from Maplins just checked and they still sell them Maplins Banana Plug code L87AZ Ł2.49 for the pair Thumbs Up Paul Tash n Barney
Post #485013 24th Dec 2015 8:10am
Cheshire110
Great thanks! Cheers, David
Post #485038 24th Dec 2015 9:53am
The plugs were widely used in vintage days and specialist suppliers of vintage electrical automotive parts usually sell them (Paul Beck, Holden, etc)
Remember that although the sockets are colour-coded, there is nothing physically preventing incorrect insertion. There was a similar plug/socket in use on quality pre-war cars where one pin was a larger diameter than the other to prevent this. These look very similar but won't fit the LR type.
Post #485047 24th Dec 2015 10:11am
Romadog
Post #485146 24th Dec 2015 5:50pm
PCA42
England 2008 Defender 110 Puma 2.4 DCPU Tonga Green
I fitted a surface mount 12v socket on the side of the dash binnacle on mine, with the wiring piggy backing off the original twin sockets so there is no damage left if removed at a later date. However, this may not be advisable because the original twin sockets are permanently live and not fused. Pete
2010 Discovery 4 GS TDV6
1972 Series III 88" 2.25P
Post #485252 25th Dec 2015 12:51am
V8_Disco
1989 Defender 110 V8 Petrol SW Auto Bonatti Grey
Shhhh I fitted a fuse behind the binnacle on the truck before the stage 1 ... Looks 100% but loads safer
Post #485272 25th Dec 2015 3:01am
