Home > Td5 > TD5 Build spec
excossack
TD5 Build spec
Got the build spec for my 1999 110 TD5 which is as follows
3.54 FINAL DRIVE RATIO
110 INCH/2794MM WHEELBASE
2650 LB. FRONT AXLE
3850 LB(1750 KG) REAR AXLE ASY
6720 LB. GVW
DIESEL FUEL CAPABILITY
LOCKING REAR AXLE - E DIFF
POWER 4-WHEEL DISC
SOLIHULL ASSEMBLY (UK)
The interesting point is LOCKING REAR AXLE - E DIFF
No ABS or TC on my 110.
Looking at the axle there are no wires for an E Diff and pretty sure its not a locking diff.
Any ideas? (Possible it might have been swapped out before I purchased the 110) 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #484202 21st Dec 2015 5:09pm
JWL
Doubtful, when I looked mine up it said that there was no tc and abs. Well it has and I don't think that anyone would go to the effort of fitting that lot on after it came out of the factory.
Post #484211 21st Dec 2015 5:27pm
shaggydog
I don't think land rover has ever offered locking axle diffs electronically or otherwise from the factory on defenders.
Special vehicles - yes quite possibly but not on standard ones.
Would love to be wrong though Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #484215 21st Dec 2015 5:41pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
I got a similar spec list for my 2004 90, including the "LOCKING REAR AXLE - E DIFF", just before I collected it.
I got all excited thinking it had some extra goodies over and above the Overdrive and stage 2 remap that I already knew about - all in vain Rolling Eyes
But it also shows, amongst other things -
"LESS ANTI-LOCK BRAKES"
which it does have Confused all to be taken with a pinch of salt I think Evil or Very Mad
Post #484221 21st Dec 2015 6:23pm
Anderzander
What's that diff manufacturer called who recently were bought out by Allmakes ? Don't they make an e locking diff that may have been used by Special Vehicles.
Post #484227 21st Dec 2015 6:51pm
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
Sorry for jumping onto a TD5 thread with TDi question.
I got similar information back from Solihull
2650 LB. FRONT AXLE
6720 LB. GVW
POWER 4-WHEEL DISC
I can confirm that Lamp Guards were also fitted through our Special Vehicle Operations Facility.
Are we convinced that the E DIFF bit s a corruption on their system. Possibly for Salisbury axle? Did the other details check out as correct for you? Mine does have discs but not ABS. 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #561509 5th Sep 2016 9:36am
Martin
Site Admin
Most likely a build code that is shared with the "E DIFF" on another vehicle (e.g. Disco 3) and there is no Defender translation for it.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #561511 5th Sep 2016 9:51am
