Home > Off Topic > Towing without a B+E - I'm confused
Page 2 of 2 <12
Retro - Thanks for the info, very useful.
I'm towing a Ifor P8e with mesh cage on a Cat B.
Very pleased with it indeed and 8' X 4' more than suits my needs and as you say isn't like those silly little car trailers that bounce about and dissapear in the mirrors...
It's the largest of it's type in-braked and plated at 228kg un-laden and 750kg gross.
So just over 1/2tonne - 500KG payload which is quite a lot unless you had something specifically heavy.
A quad or something you would need to check weights.
I've been exceptionally pleased with it, stable, handles well and reverses well too.
And with a jockey wheel it's just right for moving by hand if need be and stable when loading / un-loading when not hitched and with props down too.
Moving it by hand is a must for me as there isn't enough room to park it otherwise.
Not without blocking everywhere. Rolling Eyes
Post #483946 20th Dec 2015 3:02pm
Retroanaconda
All the quad trailers at work are un-braked and plated at 750kg or less for this very reason. It was actually a P8 that I found a massive pain behind my 90. Though it didn't have cage sides, which would improve the visibility. My dad has one which I borrowed to collect an engine (yes officer it's well under 500kg...) and it was a fiddle to reverse. Bounced around when empty too.
Now have an LM125G which tows like a dream behind the Land Rover. Don't know how I managed without it, a Defender without an accompanying big trailer is only half the story Cool
Post #483959 20th Dec 2015 3:43pm
Cupboard
I have found the source of my confusion. The rules have changed (or at least the gov.uk website has) in the last year... yay.
I printed this out in November 2014 which clearly says MAM for 2013- and weight for 1997-2013:
For me (as mentioned) that actually makes quite a big difference, and I'm a bit Censored off they changed it without making any sort of a fuss about it.
Post #491129 11th Jan 2016 7:28pm
mse
They change it a few times im sure i remember them saying that the trailer test removed the trailer weight restriction when i did it eg any weight of trailer thats legal, where as before it was limit to 3500kg trailer and i bet its different now.
So as above a coupled braked 4ton trailer would be ok Mike
Post #491149 11th Jan 2016 8:01pm
Cupboard
At one point the 1997-2013 B+E didn't have a weight limit on the trailer, so you could get a tractor unit based on a van and tow mini-artic trailers.
Post #491232 11th Jan 2016 10:35pm
mse
Yes thats when i did mine Mike
Post #491258 11th Jan 2016 11:24pm
AJC
to get round this problem, i did my class 1
Post #491315 12th Jan 2016 7:50am
RobKeay
There has always been a total train weight. Think it's 8250kg.
Post #491328 12th Jan 2016 8:44am
mse
except that doesnt technically exist C+E Mike
Post #491460 12th Jan 2016 6:32pm
Boyd
France 2003 Defender 110 Td5 SW Zambezi Silver
Just to avoid confusion as a number of people have quoted the old rules...
https://www.gov.uk/towing-with-car/driving...ou-can-tow
From the 16th Jan last year there was a suttle change mainly impacting those that passed their test after Jan '97 (and before sometime in 2012) holding a category B license, now instead of it being the gross weight of the combined 'train' being 3500kg as a limit, it's the weight being the restriction I.e. You can tow a trailer with a greater gross weight than 750kg and more specifically greater than a 3500kg train gross as long as the 'train' weight is no higher than 3500kg.
Thumbs Up 2003 Zambezi Silver TD5 110 XS SW overland prepped....
2004 Santorini Black TD5 110 XS SW left hooker for sale!
2004 Alpine White TD5 110 left hooker (work in progress)
Post #491505 12th Jan 2016 8:29pm
Cupboard
Hold on, I think you've got it backwards?
It's gone from being actual train weight to plated maximum train weight.
Post #491586 12th Jan 2016 10:24pm
Page 2 of 2 <12
