Home > Maintenance & Modifications > One Piece Bonnet Chequer Plate
jddisco200tdi
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
When installing the one piece bonnet plate, do you need to use a foam gasket underneath?
Also, has anyone had corrosion of the alloy wing top / galvanised bonnet by using stainless steel fasteners ?
Im thinking I will use aluminium or nylon pop rivets instead. Regards
John D - Defender 110 2.4
Post #48324 13th Dec 2010 6:52am
leeds
Would suggest you do not use plastic pop rivets. I would be concerned about the lonevitity of plastic pop rivets. Especially when driven on corrugated roads.
Not sure if gas gets are available for larger chequer plate pieces, as the waste factor would be large. I know a local manufacturer has gaskets made for wing tops and this is a manual operation.
Bi metallic corrosion? Have used stainless bolts and nuts on Puma wing tops with gaskets. The drilled holes were waxoyled. So far no obvious problems.
On 300Tdi have had pop rivets pop on the bonnet after doing long distances on corrugated roads.
HTH
Brendan
Post #48328 13th Dec 2010 8:53am
jerseyman
After drilling the holes touch in with an etch primer. Use Duralac on the Stainless Steel nuts and bolts. Plastic washers would also reduce the contact areas.
On my TD5, having ground out over 100 rusty rivets I refitted some of the chequer plste using Aluminium Rivnuts, partially as an isolation layer, partially for ease of refitting
Brian
Post #48331 13th Dec 2010 10:56am
Glynparry25
If it is the Mammouth 4x4 one piece bonnet chequer plate it comes with a pre-cut gasket.
Glyn Sheep
Post #48371 13th Dec 2010 5:52pm
landydubai
United Arab Emirates 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Bad fit
Mammoth checker ............ fitted it in June this year even with a few tweaks it still has a gap at the bonnet bulge front edge. Been off and on several times but still unable to close gap used the supplied gasket rivet nuts etc poor fit LandyDubai
Keep the shiny side up!
09 110 XS BAS remap
09 90 pick up BAS remap
08 D3 V8 G4 Spec
Bentley Speed GT 2009
G55 2003
Ford Raptor 2010 - new toy!
Post #48414 13th Dec 2010 8:44pm
landydubai
Mammouth 4x4 one piece bonnet chequer plate it comes with a pre-cut gasket - poor fit Crying or Very sad LandyDubai
09 110 XS BAS remap
08 D3 V8 G4 Spec
G55 2003
Post #48416 13th Dec 2010 8:47pm
Glynparry25
Re: If it is the Mammouth 4x4 one piece bonnet chequer plate
Just a quick note on this..... they had mentioned it to me that certain age vehicles have slightly different bonnet shapes and I know they have modified manufacturing to accommodate this.... might be an idea to ask your supplier Wink... might get a replacement item that fits better :thumbsup
Glyn Sheep
Post #48427 13th Dec 2010 9:50pm
landydubai
Worth a shot
Cheers Thumbs Up Spent hours on the phone from dubai with Mammouth but they stated that they had no issues at the time and basically washed their hands also had the local LR specaist body shop look at it and refit it with no improvement. they spoke to Mammouth and got the same response
Anyone had the same issues mine is 2009 Question LandyDubai
09 110 XS BAS remap
08 D3 V8 G4 Spec
G55 2003
Post #48562 14th Dec 2010 7:06pm
jddisco200tdi
Thanks for all the responses, and it is the Mammouth 4x4 one piece bonnet chequer plate .
I think i will use aluminium pop rivets and prime all the holes first before fastening. Regards
Post #48596 14th Dec 2010 11:02pm
