Home > Maintenance & Modifications > passenger door handle lose / easy fix?
Stacey007
Hello
Noticed the passenger door handle pulls away from the body a little...
Is this an easy fix, I guess the door card needs to come off... is this easy enough to do,
Thanks
Post #483524 18th Dec 2015 10:41pm
Door card stays on, use a small flat screwdriver (with tape on the end for protection.) and open the plastic tabs each side. They open from inwards outwards.
Then underneath tighten the Philips type screws.
This is the handle it's self, no removal of the doorcard required at all.
Post #483531 18th Dec 2015 10:48pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
Unless it's the exterior handle, then yes the door card would need to come off 👍
Fairly easy job, just need to be careful when popping the door card off, the plastic clips are notoriously fragile. Use a trim removal tool where you can. 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #483540 18th Dec 2015 11:13pm
Petronius4
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
It comes away from door body or door card? If its just loose on the door card custom90steve has your answer.
If the handle is lose on the door itself (but is tight against door card) then you need to follow custome90steve directions but take off handle, then as rustyboxx says carefully remove door card and re-secure - could be that you've already got some broken door card fittings (they are as previously stated weaker than Starbucks Tea...) -------------------------------
👲🏻 1986 ex-Military 90 NAD 2.5 Soft Top. Sold
🇬🇧 2015 Defender 90 - Ripon Landrover Heritage 006
Post #483562 19th Dec 2015 12:10am
Stacey007
Thanks
Its the outside door handle so guess door card off job. Is there a link for new clips as sounds like I willneed some Smile
Thank you
Post #483752 19th Dec 2015 7:31pm
Oh I see, the you are right yes. Thumbs Up
Post #483755 19th Dec 2015 7:37pm
Mountain_man
Wales
How old? Be prepared to have to replace the complete handle. They are made with a brass insert in the plastic into which a coarse threaded screw in wound from inside the door to hold it on. The brass inserts can come loose and pull out and the rearmost one is almost always seized too. I just replaced 4 doors for a mate and had to buy 4 new handles as not one of them would unscrew without destroying the handle.
The Brtipart handles are not that expensive but don't feel as sturdy as the originals n(which are about 10 times the price)
Post #483836 20th Dec 2015 12:38am
Screbble
Stacey007 wrote:
Thanks
Thank you
Hope the job goes well. It's easy enough except for the pesky door card clips/fasteners Confused
The 'fir tree' type fasteners are easy and cheap enough to buy, and I'd get a bag before you start, but also watch out for where they slot in onto the actual door card and door. Their mountings may need some repair.
Given their temperamental nature, I also added some discreetly fitted number plate screws (black caps) to the door card and there are no rattles or creaks - at least on the door cards anyway Rolling with laughter
Whilst the door card is off - there's also an opportunity to give anything in sight a bit of tic and maintenance Thumbs Up
Best of luck and all the best for Xmas,
Will
Post #483880 20th Dec 2015 10:38am
