![]() | Home > Maintenance & Modifications > defender tdci fuel filter draining |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 ![]() |
Personally I'd leave it alone or change the filter.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
^^^^ +1
rob369 Member Since: 05 Feb 2014 Location: eastbourne Posts: 17 ![]() ![]() ![]() |
Thanks Ricky, I think ill do just that and change the filter during a period of decent weather perhaps
No heard of them letting air in? Is that really the case? I've drained mine on a regular basis? But I may have air in the system and not know?
ozy013 Member Since: 10 Feb 2014 Location: Melbourne Posts: 105 ![]() ![]() ![]() |
I drain mine on a regular basis, every 2nd week, never had a problem with air in the system or the drain leaking afterwards.
Just don't completely drain the filter, or over tighten the drain valve. Mine's a 2.4, I find that draining it into a clear jar, you can see when the fuel is clear. Generally when first opening the drain till it's clear is only a small amount. Unless you've got some serious diesel snot. |
