Home > Maintenance & Modifications > DRL Bumper Wiring advice
Defender-Stu
Hi Guys, im thinking of getting a DRL Bumber for my truck as still mooding even if i may be selling lol, but do you have to solder and cut wires or can you get a plug in system? if not how do there wire into the car?
as i can be a dumb ass if you got pics that would be great lol
Stu
Post #448012 21st Aug 2015 12:57pm
gilarion
Buy one of these or similar from eBay �7.49 with free p&p. just search DRL controller then it will becomes plug and play the only joining you will have to do is a feed from one of the sidelights so that at night the DRL�s will dim as per law.
http://www.ebay.co.uk/itm/DRL-Daytime-Runn...51cbde87a4
 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #448036 21st Aug 2015 2:07pm
bittersweet
2009 Defender 110 Puma 2.4 USW Santorini Black
Am not sure that unit on ebay is legal to use in the UK
Quote:
- The two yellow wires connect to the left and right turn signals (flash simultaneously with the original turn signals)
In the UK I think all indicators have to be amber in colour.
DRL when fitted close to an indicator can 'outshine' the indicator. Many DRL dim when indicators are used.
Flashing white lights on a car is illegal except for emergency vehicles.
So I would be rather dubious to fit that ebay controller
Brendan www.4x4overlander.com
Post #448087 21st Aug 2015 6:07pm
Likeomg
that controller is the one that urban truck just sent me to replace there existing one that failed?
oh my
Post #482568 15th Dec 2015 9:46pm
VeeTee
Netherlands
I think if you do not connect the yellow wires, there won't be any flashing and you're legal again... Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #482571 15th Dec 2015 9:54pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Mud UK also do these if you do not want to splice into your existing side light.
http://www.mudstuff.co.uk/products/electri...-loom.html 2002 110 td5
Post #482591 15th Dec 2015 10:24pm
Likeomg
i've already spliced into the existing loom (had a drl bumper for about 2 months) but this new drl controller has ignition live cable, do i need this or ?
original
new
Post #482632 15th Dec 2015 11:54pm
VeeTee
Netherlands
Description on Ebay says it all:
Quote:
Wire Connection:
- Red and black wires connect to the positive and negative terminals of car battery
- Blue wire connects to ACC, with time delay function (when car starts, DRL light turns on; when car stops, the light will delay 28 seconds to turn off.)
- White wire connects to headlight (when headlight turns on at nights, the brightness of DRL light will decrease by half. )
- Green wire connects strobe light (connects with loudspeaker) (when driver press the loudspeaker button, DRL light will be in�strobe mode)
- The two yellow wires connect to the left and right turn signals (flash�simultaneously�with the original turn signals)
so... It's not that difficult, isn't it?. Shocked
It would not connect the green and yellow wires though, for legallity. Cheers, Vincent
MySite
Post #482651 16th Dec 2015 7:44am
Lost for Words
I never really see why people faff about with these DRL controllers. All you need is a relay or two.
Now, I realise there are more durable methods (i.e. transistors) but switching is not hugely frequent, so relay life shouldn't be an issue, and the cheap chinese controllers are not exactly "high quality", and if you use a standard relay, you can at least pop down to Halfords etc. should it need replacing and stick a new one straight in.
Thumbs Up Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #482676 16th Dec 2015 11:00am
Likeomg
my bad; i didnt even ready the ebay add, just had the pic urban truck sent me..
Post #482677 16th Dec 2015 11:16am
Likeomg
Hi, it turns out i need to find a ignition live, they would normally take it from the front horn but i don't have the battery backup alarm system so i need to find an alternative one... (dont worry about the alarm I've got a full aftermarket system with a few little tricks)
would prefer not to tear the dash apart and run a wire from the ignition barrel...
Post #482770 16th Dec 2015 5:22pm
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
How about taking the 12v from the radio which is painless.
Post #482790 16th Dec 2015 6:19pm
Likeomg
my dash is pretty full of all sorts of different things,
my understanding of vehicle electrics is very basic, would this be the same thing that turns my sub on / off?
think its called the 'remote' ?
Post #482791 16th Dec 2015 6:21pm
Hairysteve
There are lots of smarter sparky bods on the forum that might have pictures to explain the option but if you are no further forward by the weekend I will be wiring in some Lazers so will take some pictures for you Smile
Post #482886 16th Dec 2015 8:13pm
dioliahary
Thumbs Up
This is exactly how I have done it, also I took my switched positive from the fuel pump, fused with a 3 amp fuse.
Post #482954 16th Dec 2015 10:34pm
