![]() | Home > Maintenance & Modifications > Seat foam |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Has anyone tried a new foam base on there's ?
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5130 ![]() ![]() ![]() |
Many times over the years, works a treat and easy to do. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Who does the best
exmoor trim
no contest exmoor trim
![]() ![]() http://www.youtube.com/user/conwy1 |
I've used an Exmoor Trim kit which was perfectly doable.
Their customer service was rubbish though. |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 798 ![]() ![]() ![]() |
I would echo what 'cupboard' says. It's a very easy job to do, depending on how well sat in your seat is your cover will fit more or less well- mine had been well sat in by I presume a very hefty bloke so was quite stretched- so the fit of the cover over the new foam is a little bit baggy. Ideally you need a vice/some way of clamping the seat Base down or two pairs of hands makes it a lot easier! The seat back on the other hand is a far bigger PITA.
There's a good video on YouTube Chris |
Cheers chaps I've just swapped the 2 sides over for now
