Home > Technical > Found a connection can you help
AndrewS
Changing the head light bulbs today I found this 3 pin un used connection. Its located behind the NS headlight or the right hand side when facing the front of the vehicle.
Can anyone shed some light on this Question
The wires are Blue with Yellow marker, Black, Red with Yellow or Orange marker
 130's have feeling's as well you know Smile
Post #48226 11th Dec 2010 9:25pm
Organised Chaos
United Kingdom 2008 Defender 130 Puma 2.4 HCPU Cairns Blue
It's connector C0071 for headlamp leveling motor.
Post #48229 11th Dec 2010 9:57pm
AndrewS
Thumbs Up Thanks, not available as an option on a 130 Big Cry
I suppose I could fit them if I wanted to. 130's have feeling's as well you know Smile
Post #48230 11th Dec 2010 10:13pm
Organised Chaos
Looking at the circuit diagram you would need a 10A fuse in position 20 central fuse box, switch S109 plugged into connector C0093 located behind centre dash panel and a pair of motorised head lamp units. It would be interesting if some kind person could put a price to this modification.
Post #48231 11th Dec 2010 10:59pm
AndrewS
I will have a word with Nick at Yeovil.
http://www.yeovil.landrover.co.uk/ 130's have feeling's as well you know Smile
Post #48232 11th Dec 2010 11:11pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
if you can get it fitted might be worth the while. i found them very useful in fog, when you drop the dip it provided a bit more vision and less glare-back BM52
Post #48233 11th Dec 2010 11:23pm
AndrewS
Dont know why it not available as an option on a 130. There could be technical issues I suppose Question Question
But then leather seats are also not available for no apparent reason Rolling Eyes 130's have feeling's as well you know Smile
Post #48234 11th Dec 2010 11:41pm
Glynparry25
I would say it is for the same reason the 110DC doesn't. The springs on the back are soo strong the chances that you can lower the rear of the vehicle enough for the lights to dazzle other drivers is very very slim, where the weaker sprigs in the 110 SW and the 90 could be affected with less weight.
Glyn Sheep
Post #48372 13th Dec 2010 6:01pm
AndrewS
Thumbs Up Thumbs Up
Add the fact that its got OME 754's and the standard inner helpers on the rear, she dont sit down much when loaded Whistle 130's have feeling's as well you know Smile
Post #48379 13th Dec 2010 6:43pm
G4sweep
Germany 2012 Defender 110 Puma 2.2 XS CSW Santorini Black
Not to be a two Censored . Honest. My 110 USW has the HD springs which are the same as the DC i believe and i have the head lamp adjustment on mine? Confused
I'm open for correction though Thumbs Up
Sweep Sweep
2.2 110 XS SW
Gone;
08 D3 XS
BN55 WPV G4 4.4V8 D3.
O7 G4 Mongolian Recce 110 USW
Post #48381 13th Dec 2010 6:44pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
Are you all talking about the discovery 1 switch that adjusts the headlights? If so i have this function on my 130. 130 crew cab
98 V8 Disco
Post #48403 13th Dec 2010 8:20pm
Glynparry25
Sweep
Sweep, if it is UK spec it won't have it..... but being G4 might be to Europe spec. Same as you parktag, being European spec it will be subject to other requirements.... that is why you guys have to pay mere Wink
Glyn Sheep
AndrewS....... No chance you will get the back end of that to sag!!!!
Post #48424 13th Dec 2010 9:38pm
parktag
Ah, thats it then. It was due to go to Germany but cancelled so i bought it and imported it to France from England.
As far as the switch goes iv'e never had to use it but i should add the fact that i've only had the back three quarters full weight wise. 130 crew cab
98 V8 Disco
Post #48764 16th Dec 2010 9:53pm
shingwell
Thankful my 130 doesn't have it either. Less to go wrong!
Post #48821 17th Dec 2010 4:04pm
cradgebank
England 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I understand the deceiding factor regarding Headlamp leveling is fitted is to do with if the vehicle is a "Car" or "Commercial".
I think under C+U regulations all cars must be fitted with headlamp levelling, where as commercials are exempt of this regulation. Richard
Either a 90, 110 or 130.
Discovery 5
Post #49091 20th Dec 2010 3:20am
