![]() | Home > For Sale & Wanted > [For Sale] Defender 90 HUGE offroad spec. |
McS Member Since: 05 Oct 2009 Location: Banbury Posts: 686 ![]() ![]() |
No worries Mark, I had just assumed this was long gone, hope it all works out mate!
Ross The Scotia Winch Challenge |
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 ![]() ![]() ![]() |
Have you got some pics of the cooler set-up in the back, did you but the wheel box to give it air flow? Is that your intake pipe running out back to?
Cheers ![]() |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2710 ![]() ![]() |
Only pics of the cooler is what I've posted. I fitted this cooler as I didn't think the bogbrush cooler for the autobox was man enough. So fitted this one. Can't remember what model but JST has the same fitted albeit in a different position.
I had some long stainless hoses made up, cost over £100. ANd ran it with 1/2" or 3'4" bore hose. Not sure now it was so long ago. You then need little adaptors to get that bore of hose onto the autobox. This is where Ashcrofts come up trumps. I explained to them what I needed and within a couple of days 2 adaptors turned up FOC in the post. I then had a temp sensor brazed into the sump to give me an accurate reading of oil temp. I had the Madman gauge fitted to the dash and I think I used the alarm wires to trigger the fan on the cooler. I didn't drill air holes in the seat box to aid cooling as I thought they would allow mud/debris into the fins of the cooler. Hope that helps 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
