Home > Td5 > electrical problem with a td5 none starter
Page 2 of 3 <123>
martindavis
United Kingdom 1999 Defender 90 Td5 HT Caledonian Blue
Hi I have a friend who is going to code the injectors in for me so I can get it running at least to the specialist and go from there will let you know the outcome if all goes to plan thankyou 😉
Post #481619 12th Dec 2015 9:46pm
roel
I don't think that you can use an ECU in a defender that has been used in a disco.
A defender ECU has also the cruise controll programmed in you just need to connect some switches.
A stolen schematic off Bell Autos Services. Mr. Green
 Roel
2003 90 Td5 (2009-now)
Post #481674 13th Dec 2015 7:54am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
You can use ANY TD5 ECU in ANY TD5 car. It will run the engine, at least.
To start the engine, the TD5 ECU must be paired with AS10 (in Def) or BCU (in Disco2) or must have removed the imo function.
To run the car, you need to set correct type of throttle pedal - 2 or 3 ways, or it will just idle.
To run engine for long time, more than to closest specialist, you need proper software (map) in the ECU - basic differents are Defender/Discovery, manual/auto gearbox, Euro2/Euro3 engine.
To run engine smooth you have to set the injector codes - just try rewrite them with engine running - it will not stop, but when you change some codes to the right codes engine noise will change to a nicer and smoother one.
The injector codes are only for correction of non perfection on injectors (manufacturing tolerances of injectors) - basically it is used for slight shift of time of start and stop injection.
With wrong software in ECU there could be strange thinks like wrong working temperature gauge, or not good response to throttle pedal - this is "just" cosmetic problem. Bigger problem cam be wrong injector timing when you use Euro3 ECU with Euro2 engine and rise of exhaust gas temperature - not good for turbo.
But again - for short slow and calm move to specialist, this is not a problem. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #481680 13th Dec 2015 8:51am
martindavis
Hi all I Tryed the second hand disco ecu on the defender and a friend coded in the injectors for me and it still will not start is it possible for the discovery ecu to need the immobiliser software removed before it will allow it to start or could there be another fault ie with the starter motor or the alternater wiring will have to take a look in the day light
Post #481907 13th Dec 2015 10:28pm
mk1collector
Has the cut off switch on the bulkhead deployed? Try pushing the button back in and see what happens Ray
My build thread
Post #481915 13th Dec 2015 11:01pm
MadTom
In Def or Disco2 you have to pair the engine ECU and IMO ecu (AS10 in Def, BCU in D2). Without this, starter motor will be turning the engine, but without any diesel from injectors, because the engine ECU not commanding them.
You can check the status of engine ECU with diagnostic - if it is or is not immobilized.
With IMO function removed from the engine ECU, there will be no communication between engine ECU and AS10 (or BCU) and also less one safety function in car. And door locks in Defender are not so good, more like a demo then proper locks.
http://ok2mtm.rajce.idnes.cz/2014_07_17_-_...oru_TD5_-/ - I made some pictures - How to check the TD5 ECU security status with Nanocom EVO last year for my friend with not running car in Namibia. It worked, problem was not in ECU. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #481930 13th Dec 2015 11:33pm
martindavis
Hi l have tried cut off switch seems ok I think I will have to get it recovered to the land rover specialist and let them work there magic with the ecu will let you know what happens thanks for all help
Post #481946 14th Dec 2015 7:35am
yetiman45
England 2005 Defender 110 Td5 CSW Blenheim Silver
Why not just replace with a defender ECU ?
Post #482373 15th Dec 2015 10:00am
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
yes, you can start any Td5 with any Td5 ECU.
You need to allow the ECU to learn the 10AS or BCU (disco).
You need diagnostic equipment to make it happen it's in the ECU functions. If you swap the 10AS to another unit and then try to start the engine, it will put the ECU into immobilised and even if you put back the previous 10AS it will still not start. In this case, the ECU will allow cranking, but the immob light doesn't come on and you keep cranking and wonder why it doesn't start. The defender has migrated, leaving the owner behind.
Post #482466 15th Dec 2015 4:58pm
martindavis
Hi I went with the discovery ecu mainly because of price of a new one is about �700 from my land rover dealership and second hand defender ecus I cant seem to find any second hand ones Crying or Very sad And for �30 I've not much to lose. Hopefully going to get it recovered to the specialist on Thursday with a freelander Embarassed Censored
Post #482553 15th Dec 2015 9:08pm
martindavis
All is well we're up and running again thanks for all your help 😊
Post #484298 21st Dec 2015 10:21pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
Hi, can you tell us what you had to do to get the disco ecu to run in a defender?
Patrick
Post #484318 21st Dec 2015 11:24pm
martindavis
I tuck it to the land rover specialist but they coded in the injectors and the disco ecu had to learn the immobilizer ecu this can only be done with the computer there is a security code you need which is inside the ecu write it down and enter it when you are asked for the code to start learn I did not do this part my self and that how they done it from what I could see you can not take out the disco software as a result the temperature gauge does not work I don't know why this happens Ner Ner
Post #484338 22nd Dec 2015 1:37am
dorsetsmith
temperature gauge is driven by ECU if you can check to see if the ecu is reading temp from the sender to start with and go from where
temperature gauge out put from the ecu can also be switched off Exclamation
Post #484355 22nd Dec 2015 8:34am
MadTom
There are 2 main differences between Disco2 and Defender TD5 ECUs:
1. temperature gauge in Discovery2 works in opposite way to that in Defender - this is more or less cosmetic problem, car runs fine
2. throttle pedal response in Discovery and in Defender are different - if you place Discovery ECU into Defender, it works nearly as ON/OFF switch - car runs, but it is not comfortable on road, and difficult to use off road - it is hard to precisely control the engine.
All ECUs can be changed from Discovery software to Defender or back. Newer types with diagnostic equipment, older with soldering internal memory chip.
Third big difference is only for Discovery2 - with auto gearbox there are some additional circuits in the TD5 ECU to communicate with auto gearbox ECU over CAN line. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #484565 22nd Dec 2015 7:34pm
Page 2 of 3 <123>
