![]() | Home > Maintenance & Modifications > Bonding glass in the cold |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
I used to be in the windscreen trade.
We used masking tape to hold screens in place, plenty of strips will be sufficient. Check the sealant tube for cure times and temperature ranges. If you haven't done it before, ring a local windscreen company....(not a big multinational), or even better... a plant glass glazier who will be more used to bonding vertical glass to machines. I would recommend getting a pro to do it. |
If you do tackle it, I'll be happy to give advice over the phone.
Have you considered 'sounding out' either a local glazing specialist or someone with a workshop large enough to either fit it or having the use of his workshop to fit it late one afternoon and allowing it to cure overnight inside? I got a local approved fitter to fit my Landyglass for the same reasoning! If you go through life with your head in the sand....all people will see is an ar5e!!
