![]() | Home > Td5 > TD5 Fan control install? |
fathaggis Member Since: 31 May 2015 Location: taynuilt Posts: 385 ![]() ![]() |
thnaks mate
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1141 ![]() ![]() |
Yes it does - In Dutch!!
I have one on the shelf in the garage. I was hoping for some English instructions, but not had time to find any yet. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
epictrail Member Since: 21 Sep 2013 Location: High Wycombe Posts: 395 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
Quite a bit of work then is it that much better
No idea as i don't have it fitted or intend to fit it.
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 654 ![]() ![]() ![]() |
What about the cable that operates the flap? Do you just leave it open? 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 ![]() ![]() ![]() |
Looks like it says that in the first paragraph.
Disconnect cable and push in completely so air valve(flap?) remains open and is no longer used. "Valve and cable will no longer be used." Patrick |
Ah thanks. I'm using a mobile phone so I can't read them properly 2014 - current ..... 2003 defender td5 90 (my car)
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 999 ![]() ![]() ![]() |
I just received my kit from Landreiziger for the variable fan speed slider control. I installed the switch this afternoon, what an excellent upgrade. Cannot recommend it enough. Increases the fan speed appreciably and the variability of the slide control is just great. The install was super easy and the kit is set up to be simple.
The step by step instructions, which were included, are ok but not great. Still it was rather simple to figure out. Following the instructions I removed the gauge cluster and undid the existing fan speed switch and pushed the cable all the way in. This is an important step as if it is out, you won't have any airflow. ![]() Click image to enlarge Next I installed the new slider control switch. Important to note that the instructions were not clear on which way to install it, be sure to put the two wires on the bottom, otherwise your fan speed graphic in the dash will be reversed (ask me how I know). ![]() Click image to enlarge I ran the wiring loom through the grommet at the bulkhead after spraying a bit of silicone on the opening to ease the pulling of the wires. The wire has a cable tie wrap heat shrinked to the three wire loom for super easy insertion through the mess of wires in the dash. This is a great feature which I will use in the future (one of those why didn't I think of this years ago moments). The three pronged plug is ready to receive the wires and you just insert them and plug it into the switch. ![]() Click image to enlarge Next move to the engine bay and run the new wiring loom along the bulkhead to the fan and heater control box. Once done unplug the wires as indicated in the instructions and cut the bullet connector wires as shown below and then add on a crimped spade connector (these were not included in the kit). Connect the wires according to the colour codes indicated on the control unit. ![]() Click image to enlarge Clean the side of the air box with a good degreaser, I used brake cleaner. Position the new control unit and center punch the four holes for drilling. ![]() Click image to enlarge Drill the four holes, this can be a challenge if you have LHD with a snorkel. ![]() Click image to enlarge I chose to tap the holes for the suplied machine screws but they also provide sheet metal screws if you would prefer that. The drill to use is a 3/32 or 2.5mm. The tap was an M3. ![]() Click image to enlarge Once done, add some thermal paste (not included in my kit as it had to be shipped to me overseas and it is considered "hazardous" by some countries) and screw the new control unit to the heater box. ![]() Click image to enlarge Last to do is to choose a grounding location on the firewall. Stay away from using a wing ground. I chose the upper wing anchor bolt at the bulkhead. ![]() Click image to enlarge You are now done! Check out your easy to slide switch and improved airflow, defrosting and heating. I chose to add a few trim screws to the blank holes left by the removal of the original switch as I just don't like holes on my dash. ![]() Click image to enlarge This is an excellent mod and although a bit pricey, I cannot recommend it enough. Hope this is useful to some. Cheers. 2020 range Rover Mk IV Autobiography PHEV 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) Last edited by 4RF RDS on 11th Jan 2016 1:00pm. Edited 5 times in total |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
I have one fitted - I love it !
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2347 ![]() ![]() ![]() |
Fantastic write up. Very helpful ![]() I've been tempted to buy one myself, and if I ever do, your step by step guide will prove invaluable! ![]() |
Also important to note that my Webasto pre-heater was unaffacted by this mod. All works as it should. 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Excellent write up!
Looks like I'll need to purchase one now...looks like they are about 1.5 hours from me. Patrick |
End note to installation:
I have recently been in touch with the vendor ( Martin) and he informs me that the thermal paste was not included in my kit as it has been problematic for overseas shipping. So if you order it and you are in Europe you should get the paste. ![]() 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
