Home > Maintenance & Modifications > Bradley Autojaw
discomog
Bradley Autojaw
Has anyone fitted a Bradley semi automatic "Autojaw" combined 50mm ball and pin? If so, has worked ok, particularly when it gets covered in mud and sand etc? Have you had any problems? Thanks.
Post #481580 12th Dec 2015 6:00pm
need4speed
Never seen one of those before but it looks fairly substantial..
Post #481588 12th Dec 2015 6:54pm
JR
Scotland 1984 Defender 90 200 Tdi SW Coniston Green
The one in the pic is the latest version, I have had one since 2000, brilliant hitch especially for ring hitches and when using strops.
My older version has a bolt through the 'hinge' of the hook. I tried to remove this in order to strip, clean and rebuild the hitch but it wouldn't budge. However slackening the bolt a tad has meant that I no longer have to live with WD40 permanently dripping off the hitch! I still have to use a hammer a bit but nowhere near as much as before.
I don't know if this helps you but it certainly worked wonders on the best hitch I've ever had, oh and a few friends have bought them since seeing mine too.
Post #481625 12th Dec 2015 10:33pm
discomog
Hi JR thanks for that. I'm going to order one tomorrow.
Post #481692 13th Dec 2015 10:11am
Romadog
Really good hitch Thumbs Up
but for those that read this and dont know already
make sure you only use correct size ring hitch and also that it doesn't swivel like a NATO hitch for off road use. Thumbs Up
Post #481707 13th Dec 2015 10:53am
I have the version without the ball. It's a good hitch, but to be honest I find it has no real advantages over a conventional jaw and pjn, and have more-or-less completely stopped using it.
Romadog, I don't understand your comment about swivelling! You need the eye to be able to rotate with this coupling since the coupling is fixed.
Post #481940 14th Dec 2015 1:13am
camelman
With the nato hitch both the eye and the jaw can swivel freely thru 360 degrees
Post #481973 14th Dec 2015 11:20am
Yes, either the pintle or the lunette must rotate, but not both.both, one (and only one) must be fixed. Since the hitch under discussion is fixed, the ring must be capable of rotating.
Post #482170 14th Dec 2015 7:54pm
keith
If it doesn't swivel i wouldn't be going near it .
Personally I wouldn't tow a trailer with it, if the trailer flips it will cause the towing vehicle to do the same.
Only trailer I'd tow is one with a rotating eye.
The "Bradley Doublelock" towing hitch is one hell of a hitch, there is no doubt about that, used by the Allied forces for years.
The trailers towed at that time had rotating "eyes", which needed servicing, i.e. greasing and oiling. There were many instances were the servicing of trailers trailers were neglected, hence the rotating function failed and many incidents of trailers flipping over and the towing vehicles going over with them.
The Dixon Bate rotating Nato towing hitch was introduced and used by the Nato alliance countries.
Dixon Bate is actually a subsidary company of Bradley.
Post #482192 14th Dec 2015 8:39pm
For clarity, the hitch being questioned in this thread cannot be used to tow a trailer fitted with a NATO 76mm lunette, it will only fit a standard 40mm civilian-pattern ring coupling. As far as I know, all such couplings for braked trailers have 360 degree rotation of the ring and will be fine with the coupling.
As noted above, the early military trailers had rotating lunette and had to be towed with a fixed (non-rotating) pintle. These rotating lunettes have been phased out because a fundamental problem with this design means that if the trailer approaches 90 degrees to the towing vehicle (for example if nearly jack-knifing whilst reversing) the lunette will twist on its axis into a vertical position. When drawn forward again the lunette cannot correct its attitude and either the shaft of the lunette, or the rear crossmember of the vehicle, or both, will bend. To avoid this all recent British military trailers have a non-rotating lunette and must be towed on a rotating pintle.
All of which is fascinating but utterly irrelevant to the OP's question!
Post #482274 14th Dec 2015 11:49pm
Incidentally, returning to the OP's question, the biggest problem I found with these couplings is that when using the pin, the vehicle has to be reversed onto the trailer's eye with absolute precision or else the coupling won't engage. This is difficult if you are on you own unless you can actually see the coupling and trailer (eg with a mirror).
With a conventional jaw and pin you can almost always wiggle things so the pin will drop, but you can't with one of these.
In the end I gave up using mine under normal circumstances. It's one of those clever designs that sounds like a great idea but actually isn't as useful as you'd hope.
Post #482277 14th Dec 2015 11:58pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
I found this demo video...
also, OP asked about reliability etc.
They have a fatigue test video. It doesn't answer the question of real world use when caked in mud etc ... but could be useful at this time if anyone has trouble sleeping Laughing (it is 9 mins of your life you will never get back )
Post #482284 15th Dec 2015 12:18am
Rsmont92
I don't see any real benefit with using this type, you will still need to get out to check it is secure and to plug the lights in. plus if you cant reverse up to a trailer close enough to drop a pin in then you shouldn't really be towing
Post #482441 15th Dec 2015 3:09pm
