Home > Maintenance & Modifications > Anti roll bar
Page 2 of 2 <12
keith
Fitted today . 2hr job . No more roll , cornering transformed .
Post #480301 8th Dec 2015 4:42pm
isacs
Do you have to have lowered and uprated suspension for these to work? Or can you just have them as a stand alone item?
Post #481288 11th Dec 2015 1:13pm
Alive Tuning
Hi
Alive offer comfort lowering springs to go hand in hand with our uprated roll bar and bilstein B6 Dampers but it will work on standard springs just not to the extent it would with our full package
Alex
Post #481290 11th Dec 2015 1:16pm
redline
Switzerland
Does anyone have any advice on ARB's for a lifted 110? Mine has NO ARB's either front or rear.
I did change the springs (King +40mm with higher spring rate) and Koni Grand Raid shocks (set on Soft damping).
The handling is definitely better than stock, but I would still like to reduce the roll a little bit.
The main questions I have are:
1. OEM vs aftermarket
2. Front, rear or both?
3. As the suspension is +40mm, will I have to adapt the "tie-rods"? I assume that the greater pre-load will make them stiffer than a stock height vehicle?
Cheers,
redline
Post #482137 14th Dec 2015 6:42pm
keith
Red
If your messin about off road then you don't want your body tied to your axles.
Land rover fitted ARBs are a " Compromise " for both on/off road .
If you fit heavy duty then you'll be cornering on rails with no body roll BUT will have NO axle articulation for off road ..
Remember ' Compromise ' it's your decision .
Ps, I have a 2" front and rear lift also with no probs .
Post #482199 14th Dec 2015 8:56pm
Grenadier
....and looks more snazzy! Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #482293 15th Dec 2015 12:26am
keith
Grenadier
It'll have half an inch of black waxoyl on it shortly .
I have a big apology coming your way mate .
Pm coming soon
Keith
Post #482300 15th Dec 2015 12:35am
redline
Switzerland
Keith - thanks for the reply. I know its a compromise, but my 110 is probably spends 50% of its time on the road. And the nature of the off-roading here doesn't really require maximum articulation - the open diffs are a bigger limitation because of the traction on the sand.
Post #482326 15th Dec 2015 5:52am
Page 2 of 2 <12
