Home > Puma (Tdci) > The strangest thing Ever! on my Puma
Page 2 of 3 <123>
raulruiz110
United States 2010 Defender 110 Puma 2.4 SW Barolo Black
Hi custom90steve,
No it haven’t been on water or wet, the only wet these baby gets it’s the carwash and rain. I took it to the car wash the day I film the video, but the same thing has happen to me before.
Post #481059 10th Dec 2015 6:02pm
raulruiz110
Hi dgardel,
No I haven’t installed any Led or any other brake bulbs. And it has the stock lights of the defender.
Post #481061 10th Dec 2015 6:07pm
raulruiz110
Hi Wild card 90,
No I don’t have tow hitch, but I have noticed that when turns the indicator light the tow hitch indicator flash one time very quick, don’t know if these is natural or maybe that could be part of the problem.
No, the indicators light up very well so the brake light.
I don’t know why the engine stops.
Post #481062 10th Dec 2015 6:08pm
raulruiz110
Well I’m very glad for every respond you guys gave me, seems its have to be something electric that is giving me this odd behavior, I’m taking my landy to the mechanic next Monday, I will print all the posts and star searching with him everything you guys told me to see if I can find something, the things I will be checking are:
-Every earth connection (everywhere)
- Fuse (all of them)
-Relays
-Rear lighting circuits
-The wiring round the ignition switch
- Every wiring
I let you know if I can find the problem and fix it!. Thanks a lot!! for everything!
Post #481063 10th Dec 2015 6:11pm
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Raul, como tu 'ta?
A couple of Presidentes, a bottle of Brugal or mamajuana, dream about Semana Santa in the DN, who cares about Defenders!
Peter
Post #481067 10th Dec 2015 6:24pm
Eduardo
Raul,
Revisa que no haya algo en cortocircuito en especial el mazo de cables que va hacia las luces traseras.
Que el especialista revise si hay algún código de falla (DTC's) almacenado en el computador que controla el auto (ECU) eso podría darte algunas luces de dónde está la falla.
Llevale si puedes el diagrama eléctrico para guiarte en la búsqueda (Dgardel lo montó hace algún tiempo. Si buscas en el sitio puedes encontrar la dirección)
Saludos desde Chile Eduardo
Post #481083 10th Dec 2015 7:04pm
raulruiz110
Hey Peter klk!
hahaha!! Looks like you enjoy your visit to DR, next time you come let me know, i give you a ride on the landy and some mamajuana!
Raul
Post #481091 10th Dec 2015 7:44pm
raulruiz110
Hola Eduardo,
Gracias por tu respuesta, si eso hare. Si hace unas semana le habíamos puesto la computadora para ver si arrojaba algún código o problema, pero no arrojo nada.
Excelente idea la del diagrama electrico que subio gdarnel, lo voy a buscar. Así se nos hara mas facil el trabajo.
Muchas gracias Eduardo
Saludos desde la Republica Dominicana!
Post #481095 10th Dec 2015 7:52pm
ECU = engine control unit or engine management system
DTC = diagnostic trouble code
It is normal for the trailer indicator light on the dash to flash once when the turn signals are activated.
Post #481180 10th Dec 2015 11:27pm
raulruiz110
Hi,
Here a little video with a clear view of whats happening to me. In the video when i press the brake the engine doesnt stop, but before i start filming i press the brake and the engine stop. You can see in the video that it just happen sometimes.
Here is the link to the video
Thanks for everything
Post #481195 11th Dec 2015 12:03am
Lorryman100
@Raul, remove the instrument cluster and check the plug into the back. It sits in a groove and is not always installed correctly. The fault sounds as if it is electrical, more so on the immobiliser side (even if there is no alarm as standard there will be a 10AS unit fitted), does the immobiliser red light on the IPAC light up or flash after the engine shuts down when using the brake or the indicators, you may have to wait 30 seconds or so? If you have a diagnostic tool see what fault codes are logged in the EMS, IPAC and any events logged in the 10AS (Alarm). Post up here or pm them to me.
The brake light switch and the indicators have a feed into the instrument cluster as does the immobiliser feed to the EMS ( The 10AS transmits the mobilisation signal to the IPAC which then sends it on to the EMS). Without me actually physically looking at the IPAC and the associated wiring loom there may be a fault in the loom causing the immobiliser signal from the IPAC to the EMS to be interrupted resulting in the engine shutting down, more so if the fault occurs when the brake pedal or indicators are used as the are enclosed within the same loom. The fault could be with the IPAC ( Instrument Cluster U/S), the IPAC plug or a break in the IPAC loom causing a short. Have a look at the IPAC and wiring, if no fault is found pm me and I will tell you how to bypass the immobiliser and give a valid mobilisation signal to the EMS so the engine starts and runs. If the engine runs without shutting down when using the indicators or brake then that will narrow down the cause and where to look.
HTH Thumbs Up
Post #481200 11th Dec 2015 12:33am
LR90XS2011
Bow down DEFENDER 90 TDCI XS,
Post #481216 11th Dec 2015 7:18am
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Just watched your second video. That is so wierd. Within a matter of second, and just by restarting the motor, the behaviour changes!
Strange (and could be a clue) is that when the motor dies, no warning lights come on...until you turn back the ignition key to restart, when the dash lights briefly flash, as the key is turned back.
As Lorryman suggests, look in the direction of the ignition lock, instrument cluster and the immobiliser. Because the lights don´t come on, it could well be the immobiliser, or a bad connection to it. 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MT´s,
Recaro CS´s, anorak, wellingtons
Post #481220 11th Dec 2015 8:29am
Lorryman100
^^Or a bad earth in one of the many headers, gives the same symptoms of no warning lights displayed on the IPAC. Confused
Try replacing fuse 15 (Ignition) and fuse 30 (IPAC), give the contacts a good clean before inserting new fuses. This removes a couple of items as the culprit. Thumbs Up
Post #481310 11th Dec 2015 3:37pm
raulruiz110
Hi Everyone,
I finally solve my problem. It was this part that is located in the switching lock. Just change it and problem solve. It cost me $11 Euros. I bought it on eBay.
Thanks everyone for the help, i really appreciated.
Raul
Post #502205 8th Feb 2016 5:41pm
Page 2 of 3 <123>
