![]() | Home > Off Topic > Trickle Charger recommendations |
You won't find anything better than a Ctek. I would try to avoid charging multiple batteries in parallel since any variations in the batteries could cause problems, and an internal fault in one could, in the absence of protection, discharge or even short the others with undesirable result.
I keep any vehicle I'm not actively using permanently plugged into a Ctek pretty well all the time now. |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 727 ![]() ![]() ![]() |
+1 for the C-tek, they can be left on the battery indefinitely and I've never had a problem with them. One of them lives outside and has survived a winter with no issues.
I bought a Lidl one a few months back, for £15 it's coped very well charging Puma batteries from dead. It can be fitted to the battery long term and automatically reconditions like the C-tek. The Halfrauds ones are mean to be quite good also. |
ethanicus Member Since: 11 Jan 2013 Location: Surrey Posts: 94 ![]() ![]() |
+1 for ctek chargers. I use the 0.8 xs as maintenance charges for winter storage. Just fit and forget. Never had any issues.
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
C-Tek
Looks like I will be buying a few more Ctek chargers
![]() Currently have 2, one is about 3.5 amp, one is a 7 amp one. The 7 amp one at 6 years old is not working at the moment, not had time to check the fuses yet. Brendan |
It certainly seems to make sense, with any type of vehicle that is not used constantly, to plug them in permanently
to a CTEK. Very impressed with mine and I think it has paid for itself in not having to replace batteries every 3 or 4 years. |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
Also use a couple of Ctek for the trickle charge jobs
then a GYS Batium http://cheshirebatteries.co.uk/chargers-te...arger.html for proper charging California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Shame you missed the deals Amazon were doing on the Ctek
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1371 ![]() ![]() |
I have a CTEK one on my old escort,
I also use an Accumate but i do have 3 x £10 ALDI ones and in all fairness they all do exactly the same job for the price of one CTEK. |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
Just to be different....
![]() I have a Halford's one and it seems to work fine ![]() ![]() |
Seriously - they have the same 7 or 8 stage charging & maintenance modes? |
Yes. It keeps the battery charged. That's all I need.
They even have a digital display showing volts and how charged it is etc. Only thing that lets them down is you can't unplug the crocodile clip cable from the charger like you can with my c tek. |
treps Member Since: 07 Jul 2015 Location: SE Posts: 244 ![]() |
For other cars I normally use an Optimate 6 which I have for the bikes... Has worked fine.
What model CTek do you recommend? |
g-dog-s Member Since: 27 Aug 2015 Location: Surrey Posts: 16 ![]() ![]() ![]() |
I have a CTEK MXS5.0 (not the Test & Charge) which is fine for 1.2Ah to 110Ah batteries inc lead acid, AGM & gel.
This does the job on 12Ah gel & 16Ah lead acid motorbike batteries as well as looking after the batteries on a D4 (AGM) and 110 Puma (lead acid) (Individually, that is, not all at the same time!) The cars are charged via the towing electrics using an adapter bought from Martin of this parish |
