![]() | Home > Technical > Mice in the engine bay of my TD5 |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5971 ![]() ![]() |
Yeah,
![]() Simples Andy |
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 ![]() ![]() ![]() |
turn all your lights on, HRW etc, revv engine to see if lights brighten or squeek gets worse
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 ![]() ![]() |
Squeak goes away when you rev it..... |
It is as if they have joined the belt on the cheap belts and the ridged join causes a sqeak.
Andy |
Cheers for the advice, will replace at the weekend. best to get genuine LR? |
yes, and keep the other as a spare so you won't need one.
Andy |
Cheers Andy, much appreciated. ![]() |
Guess: probably the belt needs a little tighten having settled in and stretched since new.
Potentially could be an oil leak dripping onto the belt.....not sure if this engine is prone - not sure I've seen any posts on such a problem |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
crank pulley on it's way out.
see here http://www.discovery2.co.uk/CrankPulley.html very good right up. |
just been and checked with the fan cover off. Belt looks in good condition and doesn't seem slack, 12mm of deflection exaclty. Just what the workshop manual says..........mmmmmmmmmmmm
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
My tensioner had partly ceased and was causing my belt to squeal when starting, stopping and moving off at tick over.
Took the tensioner off and soaked it in GT85 and fitted a new Dayco belt, stopped the noise for a while but its coming back so will get a new tensioner. Pete. |
Spray some WD40 on it.
Works every time. |
Taking the car back to the dealer in the morning.
Couple of things, The tensioner pulley has a visible (if not significant) vibration / movement when the engine is running - is this normal? When the engine is coming up to temperature the noise starts to subside and when fully up to temperature the noise goes completely (at idle, fast idle and full load) |
Just check your exhaust manifold studs while your looking around there, it would explain why the noise goes when things warm up. Had a few friends that have changed there fan belt because it squeals and it ended up being a broken or loose stud in the manifold.
Pete. |
