Home > Puma (Tdci) > Recalls for the puma?
Page 3 of 4 <1234>
MK
Already 3!!!!!! Jes. Did they give any smart explanation? Puma 110" SW
Post #15813 23rd Sep 2009 10:35pm
scatt
England 2008 Defender 110 Puma 2.4 DCPU Alpine White
3 clutchs is only the start of it, and i got no explanation/ excuse.
Post #15864 24th Sep 2009 7:57pm
Pres49
Hi all,
Sorry for open this post again but my blood is boiling!! I have 2008 90 SWSE and went many times to dealer with many of thoses symptoms described in this post.
1) knocking noise in engine when start, if you put pressure on clutch for seconds it disappear: they said that,s normal and was front promshaft.
2) crancking starter motor and block of ignition switch.
They changed in warranty: turbo( blowing a lot), brake master cylinder( loose a lot of oil), and more than 10 parts that I don,t want to remember because there was a discussion in each one of them.
My question is that if I go again with this "recalls"(for me the most important is the two described above) and my car is between those frame and engines numbers, even if my car is out of warranty, Should they take charge of the repair of the car??. I,m in Spain( where every thing is normal),
Thanks
Pd: I'll be for months in London next year, do you think is better there??
Post #366345 22nd Oct 2014 6:43am
http://www.dft.gov.uk/vosa/apps/recalls/searches/search.asp
There are 9 showing, although one references a Freelander:
Launch Date Recalls Number Make Model(s) Concern VIN Start VIN End Build Start Build End
1 22/06/1993 R/1993/050 LAND ROVER Defender perforations in inner tube LD925367 to LD925913 04/01/1993 15/01/1993
2 05/06/2000 R/2000/038 LAND ROVER Discovery and Defender Td5 Diesel engine flywheel may fragment XA200000 to XA244647 (Discovery) 01/09/1998 30/06/1999
3 22/10/2001 R/2001/017 LAND ROVER Freelander insecurity of front seat backrest. 1A300000 to 1A320519 01/08/2000 28/02/2001
4 22/04/2002 R/2001/171 LAND ROVER Defender left hand front brake flexible hose concern XA159961 to 1A617058
5 31/03/2004 R/2003/180 LAND ROVER DISCOVERY II and DEFENDER (where ABS is fitted) possible loss of service brake XA162896 and YA600000 YA199999 and YA671407 01/10/1998 01/12/2003
6 04/12/2009 R/2009/091 LAND ROVER Defender parking brake may become ineffective SALLDHMS87A740136 SALLDVBS88A757662 07/06/2007 13/02/2008
7 04/04/2011 R/2010/232 LAND ROVER Defender parking brake efficiency can be affected 05/10/2007 04/11/2010
8 08/08/2012 R/2012/069 LAND ROVER Defender (Including Defender 90 & 110 Chassis Cab, Truck Cab, Soft Top, Hard Top, Pick Up, High Capacity Pick Up vehicles and 130 Double Cab Pick Up). seat belt mounting bracket may fail 01/02/2010 31/01/2012
9 28/11/2014 R/2014/092 LAND ROVER Defender front wheel may detach SALLDHMT7BA820580 SALLDHSS8BA408691 01/09/2010 05/07/2011
[ 1 ]
Post #468967 3rd Nov 2015 10:51am
Crofter
United Kingdom 2009 Defender 110 Puma 2.4 USW Baltic Blue
I have only received one recall and it was for a seal which may leak and I think this would effect the brake I think parking brake. I have a 2009 Defender 110.
Post #469248 4th Nov 2015 8:34am
Caterham
me too.
Post #474152 19th Nov 2015 12:15pm
bwganbrain
Wales
How can I find out if my vehicle has been "recalled"?
Thanks
Post #479680 6th Dec 2015 5:53pm
LR90XS2011
dont forget the seat belt bracket on 2011 models DEFENDER 90 TDCI XS,
Post #479686 6th Dec 2015 6:04pm
A bit of a thread revival here after many years but I have been reading info regarding the Sump recall.
As some of you may know, mine has developed a leak, however, thinking about it I cannot ever remember a Sump recall being done or requested.
That being said, I was not the first owner 2007 - early 2010 @12k.
Is there a way of checking at all? There was a seatbelt bolt and handbrake one I can remember but not sump related. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #697551 31st Mar 2018 10:51pm
dgardel
Italy
Sump recall only for early 2007...
Go to a dealer and check by VIN (or check here https://topix.landrover.jlrext.com if you have a login) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #697562 1st Apr 2018 12:14am
LR90XS2011
recalls can now also be checked on the DVLA website, cant say how accurate it is thought DEFENDER 90 TDCI XS,
Post #697567 1st Apr 2018 6:36am
The sump wasn't actually a recall, you had to ask for it to be done. If you didn't ask, it won't have been done.
Post #697578 1st Apr 2018 9:08am
ericvv
Here you go.
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #697596 1st Apr 2018 11:00am
"tolerance variation" Laughing
There is a very special language they use in these publications.
Post #697599 1st Apr 2018 11:26am
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
The dealer who used to service my 07 Puma 110 SW asked me if I wanted the sump replacing, I don’t think I got an official recall as such but they were happy to do it for free, I declined as the vehicle was mainly used on the road with little in the way of off road.
Post #697609 1st Apr 2018 12:27pm
Page 3 of 4 <1234>
