Home > Puma (Tdci) > Rear Seats
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Rear Seats
I've had a quick scan through but cant find a previous post, has anyone removed the fold down seats?
I'm away this weekend with the lads, but 3 people and kit for a few days walking/drinking just wont fit.
Just wondering if its a 5 min job to remove/replace
Rosco 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #47952 9th Dec 2010 1:04pm
MK
In a 110", last row removal takes more than 5 mins. Haven`t seen a 90 setup.
Bolts are ultra-tight, so you need good quality torxs. I recommend you spray them with WD40 or so before. Puma 110" SW
Post #47957 9th Dec 2010 1:45pm
gtveloce65
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Epsom Green
Took me longer than I expected - there are 4 torx into captive nots for the floor/seat support mountings which are a bit fiddly due to the cut outs in the carpet, and I think it was 2 torx and a threaded stud (with the nut on the wheel arch side) for the seat brackets. Getting the covers off the brackets with their pathetic plastic screw fittings is a delicate operation if you want to reuse them, and as MK says, everything else can be very tight, especially if the ends of the torx screws have corroded at all - break out the WD40, or similar.
Took me around 20 nins to do one seat (which gave me the extra space I needed) and I've left it as a 6 seater for the time being - I just taped over the various holes in the floor and seat box/wheel arch as a temporary measure rather than screwing all the torx back in...now where did I put all the fittings... Confused 1953 80
1965 Alfa Romeo GT Veloce Sprint
1980 Fiat 124 Spider
2008 110xs
Post #47980 9th Dec 2010 5:11pm
mse
Somewhere on here a search will show you the answer you require. Mike
Post #47992 9th Dec 2010 6:36pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Recommend you photo the springs, cos you'll forget how they go back in Whistle Original Member Pie n Pea Club.
110 HCPU Tipper
Post #47997 9th Dec 2010 7:16pm
ian964
Yep, best part of an hour to take them out. I suspect it will be longer to put them back!
Post #48005 9th Dec 2010 8:47pm
Lorryman100
Not to mention the hernia in lifting them out of the back Whistle
Post #48007 9th Dec 2010 8:53pm
BigMike
took me about an hour. had to grab a neighbour to help with a spanner on the nuts
Post #48014 9th Dec 2010 9:07pm
Rosco
Thanks for the advice all.
Thankfully I'd decided to leave them in place as 1 of the guys dropped out last minute. Rolling Eyes 2007 - Stornoway Grey 90 XS SW - Gone
Post #48335 13th Dec 2010 12:35pm
