![]() | Home > Td5 > Help, stranded |
Motoberg Member Since: 01 Oct 2015 Location: Aberdeen Posts: 104 ![]() ![]() |
Just getting a click when I turn the key, battery seems fine, lights aren't dimming like I'm pulling many amps.
Anything I can hit ? |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 ![]() ![]() |
immobiliser?
try getting out of the vehicle; locking it; then unlock and try ignition again. my tdci has played tricks on me like that |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
alway worth citing starter motor!!
![]() my youtube channel |
Tried that, unfortunately not
Relay under driver seat
![]() if is starter motor see link below http://www.aulro.com/afvb/projects-tutoria...r-diy.html |
If it clicks I'd say starter motor too, it should jump start. Ray
uncas Member Since: 22 Nov 2012 Location: Wentworth near Rotherham Posts: 340 ![]() ![]() |
Broken earth lead gearbox to chassis. I had similar symptoms and changed my starter when it still wouldn't start we investigated further and eventually found that earh lead terminal end had broken at the gearbox .
Uncas |
Thanks Chaps, I need to go back to work this morning to pick it up, I'll get a tow start to get it home and see what I can find.
special tap on the solenoid with a calibrated hammer did the trick !!
best think about a long term fix though ! Thanks all |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 981 ![]() ![]() ![]() |
The solenoid contacts! Bottom one is worn after 100,000km top is brand new.
![]() Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Solenoid contact kits on eBay are only about £15/£20 and are really easy to fit Ray My build thread http://www.defender2.net/forum/topic17615.html |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1785 ![]() ![]() ![]() |
This is a very timely topic. Over the last few days mine has developed a habit of clicking when I turn the key, then only turning over a few seconds later. Likely to be the same problem?
Dat's da symptom dude... Didderdun quickly!
![]() ![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
