Home > Wheels & Tyres > tyre sizes for Boost alloys
Page 2 of 2 <12
jst
johnszs wrote:
255 85 16 any good for.ypu james?
they would be if i could get a BFG AT in the that size. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #479167 4th Dec 2015 8:22pm
jst
so, will 285s fit width wise on a boost rim? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #479168 4th Dec 2015 8:22pm
Swac3
Seeing as you asked, No they wont, not if you comply with the manufacturers stated rim size.
Of course if you want to ignore that and any legal/insurance issues that may crop up if you do have a bad day, then, as many people will tell you, they have them fitted and never had any problems..... etc etc.
Your call. 3 Landrovers
Post #479179 4th Dec 2015 8:54pm
jst
thank you Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #479756 6th Dec 2015 8:25pm
jst
what width is a LR Boost alloy please? plus a SVX style dual tone? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #656770 12th Oct 2017 1:14pm
Boosts (and Deep Dish) alloys are 7" wide, 33mm offset.
Sawtooths are 7" wide, 20mm offset.
I don't have data for the SVX dual tone, I am afraid.
You can run 285/75 x 16 BFG tyres on Boosts with no problems, however (1) the rims are narrower than tyre manufacturer's minimum recommended minimum, which could conceivably cause an issue in the event of bad things happening (although I have never heard of an authenticated case of there being issues - it seems to be another of the many Internet legends), and (2) 285s on Boosts do have a detrimental effect on turning circle. This can of course be mitigated with 30mm spacers, but then you will get crud up the side of the vehicle in huge doses, and also fall foul of the "spacer police" who will tell you that they're dangerous and your soul will burn for eternity for fitting them. Once again, however, they are quite safe if used and fitted properly.
Clearly you should tell your insurance company, etc., etc.,
it is a great shame that BFG seemingly have no intention of making the AT KO2 in 255/85x16, since it is the ideal size for a Defender and I am sure would be a good seller. I don't know why they make the KM2 in this size and not the KO2.
Post #656774 12th Oct 2017 1:55pm
geobloke
Hi JST. the standard Boost wheel is a 16" x 7" with a 33mm offset.
I have just fitted 285/75/16 BFG AT KO2s on these and they fit just fine. Many many folks running this size tyre on Boost wheels.
235/85/16 Vs. 285/75/16
Full 285 setup
Post #656775 12th Oct 2017 1:55pm
Hall46
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
That looks perfect Thumbs Up any spacers??
Post #689153 26th Feb 2018 11:12pm
Page 2 of 2 <12
